Skip watering moisture for Bermuda lawn
Fran Roman
Actualizado 2021-03-09 20:30:13 UTC
Hi! I just installed my brand new whisperer, and I’m wondering which value I should configure for the skip watering functionality (80% by default). I have the perception that is too high for a Bermuda lawn.
Ver: 3889   Respuesta: 1
Foreca as weather provider
Fran Roman
Actualizado 2021-03-09 21:21:35 UTC
Please add Foreca as weather provider! In Europe is much better than the available options on the app. Metro group is also a good option for your European customers like me.
Ver: 3967   Respuesta: 1
Netro pixie Internet off
Andrea Zorgniotti
Actualizado 2021-03-14 07:08:00 UTC
Hi, I'm the owner of a Netro 6 channel at my primary home where I use the smart watering function with no program, after 4 years I found the correct configuration and I'm really happy about the complete automation. In my vacancy home I bought a Pixie few weeks ago. I'm afraid the connection could be off when I'm not there. In the last weeks I set a program with 1 day on 5 min and the next off and the smart watering to check the rain and cancel the day raining. I would like to use the Pixie in the complete automation like in my principal home. So my question is what happen if I set only smart watering and then internet go off? Is it scheduled inside the Pixie a sort of program of watering that works anyway and the plant will receive water (even if in not an optimized way)?
Ver: 4262   Respuesta: 1
What does the app show for whisperer?
Growbro
Actualizado 2021-03-17 20:54:48 UTC
I am trying to figure out what the graph shows for the week. It seems like the app shows the average light for the day. Moisture present at midnight each day. And average temperature each day. Is this correct? Or is it maximum temperature for the day?
It would be nice if I could have the graph could show more than just one reading per day. It would also be nice if you could go back and see the more detailed chart for a full day after it has passed. As it is now I can only see the one data point for days that are past.
Finally for the individual days it is a bit annoying switching between am and pm. I wish there was just a graph for each day that looked like the graph for the week/month except that there was a data point for every hour. Definitely more annoying and less useful to have am and pm separate and not be able to see the changes like you can with the graph.
Ver: 4030   Respuesta: 1
Standalone whisper asking me to water every day
MartynCarr1972
Actualizado 2021-03-18 08:43:41 UTC
Hi have a standalone sensor in  a pot indoors. For the last 4 days since I have had it running its asked me to water every day. Which I have. I would like to know what the parameters for my plant are for it requesting water.
Also it shows 2% battery in the app in the day and 0% at night. The web app shows 15% all the time it seems.
Anyone have similar issues?
Ver: 4323   Respuesta: 1
When will be Netro Smart available in Europe?
Raúl Vázquez-Noguerol Méndez
Actualizado 2021-03-20 20:38:05 UTC
I’d like to know if Netro Spark will be available in Europe.
Ver: 3905   Respuesta: 1
No power to controller
Barbara Williams
Actualizado 2021-03-23 16:10:05 UTC
Our controller has been working fine, and we had to replace some solenoids that were faulty. The controller is plugged into a verified live socket but no lights turn on. I can't hook up wifi, and it appears to be dead.
Ver: 4093   Respuesta: 1
sprite subscription
Alejandro
Actualizado 2021-03-24 09:06:34 UTC
I am interested in buying the netro sprite but there is something I dont understand about the annual subscription (I do not understand English very well).
What stops working in the netro sprite if I don't have a renewed subscription?
Ver: 4358   Respuesta: 1
Ideal Soil Moisture
Mike Biondo
Actualizado 2021-03-26 01:51:09 UTC
What is an ideal soil moisture level? My new Netro Whisper is measuring 83% down from 88% 3 hours ago. Is this too moist? It is average raised bed plant soil. I have googled and found some sites saying no more than 45% and some sites say no less than 70% so I am very confused!
Ver: 5772   Respuesta: 1
Wild Swings In Moisture %
Mike Biondo
Actualizado 2021-03-27 22:08:54 UTC
I am seeing 20%+ increases in soil moisture when there is no rain and I am not watering and also 20%+ reductions in moisture directly after watering which seems counterintuitive. Is this normal? Can anyone explain what is going on to me? Thank you!
Mike
Ver: 4249   Respuesta: 1
Kevin Westling
Actualizado 2021-03-28 06:40:48 UTC
Ver: 4043   Respuesta: 1
Actualizado 2021-03-29 08:57:05 UTC
I have checked in the smart schedule that tomorrow is programmed to run zones that should be skipped.
I have set up the whisperer to skip run if moisture is above 40%. Current moisture is:
  • Zone 2 - 92%
  • Zone 5 - 70%
Ver: 4498   Respuesta: 2
Server offline
Mirko Paganelli
Actualizado 2021-03-30 16:15:01 UTC
Ver: 4086   Respuesta: 1
What do the icons mean?
Jim Stichbury
Actualizado 2021-03-31 06:55:06 UTC
Ver: 4067   Respuesta: 1
Firmware update
Francesco Angelone
Actualizado 2021-04-01 13:33:34 UTC
my firmware version is the 1.1.1
Please, can I have the last firmware vesion and the instructions for update my controller.
The serial number is E4956E4B6B05
Ver: 4318   Respuesta: 1
Light flashing
lightnin
Actualizado 2021-04-01 19:11:23 UTC
Why is my light flashing on my Netro?
Ver: 4083   Respuesta: 2
Instant watering
hermanins@gmail.com
Actualizado 2021-04-03 00:01:28 UTC
Ver: 3874   Respuesta: 1
Many inexplicable Manual runs
Panos Charalambopoulos
Actualizado 2021-04-03 11:37:15 UTC
Hello everyone ,
Ver: 4038   Respuesta: 1
Does the Pixle have to be installed with the water coming into it on the "Hose Faucet Connection" side?
Austin Franklin
Actualizado 2021-04-03 19:04:13 UTC
Basically, is the Pixie water control valve one way, or can it shut off/turn on with pressure from either side?  In order to install it so the button faces up, I need to install it so the water comes in what is labeled as the "Outlet" side.  I don't know if it's labeled "Outlet" because it is a male connection, or because it cares about the direction of the water.  Otherwise, I will need to buy a male/male and female/female adapter, flip it "upside down" and use it with the button facing down.
Ver: 3999   Respuesta: 1
Can’t start Netro
Joe Horner
Actualizado 2021-04-05 14:47:49 UTC
I have a good WiFi signal.
Ver: 3870   Respuesta: 1
