Simple on/off
gmcg1984
Actualizado 2020-09-17 01:54:35 UTC
Ver: 4167   Respuesta: 1
Multiple sprinklers in one zone - and is there a Test System ?
Cormac Champion
Actualizado 2020-09-19 13:48:55 UTC
Can zones be setup with several sprinklers in the one zone ?  From what I can see from another question, is it correct that you setup the aproximate size of each zone ?  I have several zones with maybe 10 sprinklers in each zone, with sprinklers about 3m apart.
Also, is there any access to a test / simulation system that I can setup my location and see how well it would adapt to weather.  I am planning the installation for southern Spain
Thanks in advance
Ver: 4428   Respuesta: 1
HomeOwner
Isaac Fishman
Actualizado 2020-09-21 01:14:55 UTC
Ver: 4150   Respuesta: 1
Controller LED Light
Texas AF
Actualizado 2020-09-22 14:01:57 UTC
Ver: 4103   Respuesta: 1
Second house
HaccasDave
Actualizado 2020-09-29 18:20:51 UTC
I'm in the very fortunate position of having 2 homes - one in the UK and one in Spain. We've just had the garden reworked in the UK and I've been able to install an irrigation system controlled by a single Sprite controller.
I'm very pleased with how this is working - and now want to upgrade the manual irrigation system we have in our Spanish house to a smart system. Can Netrohome / the (Android) app manage 2 different irrigation systems in 2 different locations (with 2 very different climates)?
Many thanks.
Ver: 4299   Respuesta: 1
Atif Khan
Actualizado 2020-10-01 14:21:57 UTC
Ver: 4082   Respuesta: 1
OFFLINE
Javier López-Guerrero
Actualizado 2020-10-03 08:20:26 UTC
Help!
Javier
Ver: 4085   Respuesta: 2
Switch Off automatically
Carlos Jimenez
Actualizado 2020-10-09 20:18:31 UTC
I found two cases,
Ver: 4199   Respuesta: 1
Simone Nolletti
Actualizado 2020-10-11 11:46:06 UTC
Buonasera,
Ver: 4584   Respuesta: 1
Questions about Netro app
Luis Aguilar
Actualizado 2020-10-11 17:47:55 UTC
Ver: 4204   Respuesta: 1
How stop 1 day
Leonardo Antonucci
Actualizado 2020-10-11 18:33:55 UTC
Ver: 4120   Respuesta: 1
"Next in" shows "--"
Luis Aguilar
Actualizado 2020-10-14 18:45:01 UTC
Ver: 4155   Respuesta: 1
Netro unit
Bhumit Joshi
Actualizado 2020-10-16 18:15:51 UTC
I just got my system winterized today. Netro box is still on. Do i just unplug it for the winter?
Ver: 4229   Respuesta: 1
Problem With application
Alex Guerrero
Actualizado 2020-10-17 08:21:08 UTC
Ver: 4154   Respuesta: 1
Manually entering rainfall
Curt Lizzi
Actualizado 2020-10-17 13:16:09 UTC
Ver: 4358   Respuesta: 1
David Farries
Actualizado 2020-10-24 20:24:40 UTC
Ver: 4408   Respuesta: 1
Email address length
Alberto Castro Hinojosa
Actualizado 2020-10-24 21:37:57 UTC
Could you review please?
Ver: 4287   Respuesta: 1
Stefan Pena
Actualizado 2020-10-25 10:41:41 UTC
Hey guys!
Ver: 4073   Respuesta: 1
New user
Haris Eliades
Actualizado 2020-10-28 20:35:38 UTC
Hello!
Zone 4, 2 minutes
Zone 5, 2 minutes
Zone 1, 4 minutes
Zone 2, 4 minutes
Zone 3, 4 minutes
Zone 4, 4 minutes
Zone 5, 2 minutes
How do I turn off for Winter?
Paul A
Actualizado 2020-10-30 20:59:47 UTC
Ver: 4073   Respuesta: 2
