Moisture and light range
Don Lewandowski
Actualizado 2020-12-31 21:46:19 UTC
Ver: 5554   Respuesta: 1
Darren Cassar
Actualizado 2021-01-05 11:03:18 UTC
Darren
Ver: 4141   Respuesta: 1
MAC address
John Conley
Actualizado 2021-01-07 15:26:26 UTC
Ver: 4073   Respuesta: 1
Technical question
Enrique Campos Sanchez
Actualizado 2021-01-14 20:36:25 UTC
Hi team.
I would like to know what is the maximun wire longitude that support by zone the Netro Driver using 24 VAC power supply.
Thank´s.
Ver: 4261   Respuesta: 1
Geron R
Actualizado 2021-01-19 23:06:52 UTC
Please advise
Ver: 4177   Respuesta: 1
Cancel
Awilda Betancourt
Actualizado 2021-01-24 13:09:23 UTC
Date Format
Brian Keenan
Actualizado 2021-01-29 09:00:07 UTC
Ver: 3987   Respuesta: 1
Smart Watering Algorithm
Actualizado 2021-02-09 13:52:56 UTC
Ver: 4551   Respuesta: 1
Turning off
Rony Z
Actualizado 2021-02-15 13:58:39 UTC
Ver: 4119   Respuesta: 1
AMC
Actualizado 2021-02-18 13:04:06 UTC
hello,
¿How Can I solve this issue?
APP version 2.5.3
Ver: 4165   Respuesta: 3
Valve sttoped
Carlos Jimenez
Actualizado 2021-02-18 21:28:28 UTC
Hi, I will apreciate if someone can help me, I'm going crazy, becouse suddenly, one of the solenoid valve stopped after 10 seconds. But the app show that it is running. I changed the valve with a new one, but same 7-8 seconds after run, it stoppes. Pls help me! Thanks
Ver: 4101   Respuesta: 1
WiFi link
Benedetto
Actualizado 2021-02-20 17:56:18 UTC
Hi, i would appreciate if someone could help me. I need to link the netro to the router without password, however the procedure need a password in any case: how can I do? Thanks for the support
Ver: 3904   Respuesta: 1
explicit instructions on how to add weather station weather station, namely weatherunderground personal weather station
Joe Ryan
Actualizado 2021-02-24 00:01:13 UTC
explicit instructions on how to add weather station weather station, namely weatherunderground personal weather station. How do you add station ID
Ver: 4325   Respuesta: 1
Zone says Loading
Gale
Actualizado 2021-02-24 14:03:11 UTC
After the numerous power outages in Dallas last week, my sprinklers attempted to run this morning.   At its scheduled time, the zone shows "loading" but - no water.   ???
Ver: 3836   Respuesta: 1
How many electro valves
javyto98
Actualizado 2021-02-25 21:52:58 UTC
Hello I would like to know how many electro valves I can open at the same time?
Ver: 3805   Respuesta: 1
Ignoring Restrictions for one zone
Brodie Lewis
Actualizado 2021-03-01 02:55:53 UTC
Hey Team,
Have one zone that is connected to drippers in an undercover area with hanging baskets
Need to set a regular schedule for watering in this area, that ignores restrictions for this area, but still applies for other zones.
Is this available in the app at the moment?
Ver: 3954   Respuesta: 1
How to add additonal members
Vijay Chidambaram
Actualizado 2021-03-04 03:19:58 UTC
We have installed Netro Sprite system yesterday
we like the Netro app to manage the programs.
My question is this: How do i add additional members of the house the same access to manage the programs ?, such as altering zone level scheduling etc.
Ver: 4387   Respuesta: 1
Sensor not starting
Joan Peiro
Actualizado 2021-03-06 08:53:31 UTC
Good morning
I have received two days ago my new sensor. I am not able to start the sensor to proceed with the installation.
When I press the power button it makes a short flash in red after releasing but does not turn to white , blink or green.
Same effect when I press quickly  three times or six times.   It only produces a short flash in red.  I can not proceed with the installation as my app does not find the Netro wifi of the sensor as it is off.    I tried to leave the sensor under solar exposure for a full day with no change in the behavior.  Still just a short red flash after pressing the power button but nothing else.
Can you guide me how to solve the problem?
Ver: 4328   Respuesta: 2
Selling our house - transfer sprite to new owners account
Tod Johnson
Actualizado 2021-03-08 13:29:28 UTC
We are selling our house. How do we transfer the current sprite to the new owners without resetting all the settings?
Ver: 4220   Respuesta: 1
App non si configura con IPHONE 7 Plus iOS 14.4
Antonino Marretta
Actualizado 2021-03-08 08:10:40 UTC
Salve a tutti, come da titolo la app durante la configurazione con smartphone in questo caso un IPHONE 7 PLUS con iOS 14.4 non riesce a completare l’accoppiamento con Netro , ho riprovato con smartphone Android con successo.
Ho fatto presente l’anomalia anche all’azienda costruttrice, la quale ci sta lavorando.
Chiedo a qualcuno di voi se ha avuto lo stesso problema.
Ver: 3610   Respuesta: 1
