Skipping watering
Sid Smith
Actualizado 2021-06-10 21:05:17 UTC
Ver: 4137   Respuesta: 1
Marigolds
Actualizado 2021-06-10 23:51:43 UTC
What is eating my marigolds
Ver: 3993   Respuesta: 0
Whisperer won't blink white during setup
Kevin Westling
Actualizado 2021-06-12 03:01:46 UTC
Prior to installing a whisperer to my system, I set it up outside in direct sunlight for 5 days. When I try to add it to my Sprite, the light only blinks red once. I've tried multiple times to press the power button 6 times and it's still just flashing red just once. What am I doing wrong?
Ver: 4527   Respuesta: 1
Change sensor zone?
Jeff W
Actualizado 2021-06-12 14:23:07 UTC
Ver: 3908   Respuesta: 1
Confused....to sensor or not to sensor?
Kevin Westling
Actualizado 2021-06-12 14:37:12 UTC
I'm only using a sprinkler system to water St. Augustine grass on a .2 acres in South Florida. The entire area is flat and has the same soil make-up (loam). Direct sunlight shines mostly all day on every area other than a small 10'x40' strip on the west side of the house that is shaded part of the day. I have no trees and no plants. I have a Sprite controller and 1 whisperer sensor which is connected to the 3 zones that get the most sunlight. The learned % is at 55%
I don't see any benefit in using the whisperer. Thoughts?
Ver: 4105   Respuesta: 1
Text overlap in App
Kevin Westling
Actualizado 2021-06-12 14:46:02 UTC
Ver: 4023   Respuesta: 1
Installation of sprite
Mark Killeen
Actualizado 2021-06-12 21:53:35 UTC
I have all connected and seems fine but when testing turning on each station I get a "pending" but no sction!
Each zone then said"loading"  for 5 minutes each then nothing. Please offer any help!
Ver: 4464   Respuesta: 2
Connection issue
bridgethr
Actualizado 2021-06-13 18:17:52 UTC
Ver: 4154   Respuesta: 2
Whisperer Bad Readings
Billy Wood
Actualizado 2021-06-13 19:42:18 UTC
Ver: 4030   Respuesta: 1
Rebekah H
Actualizado 2021-06-13 19:48:23 UTC
Any ideas?
Rebekah
Ver: 4082   Respuesta: 2
whisperer + smartzone
Actualizado 2021-06-14 20:59:45 UTC
Ver: 4424   Respuesta: 1
Backup
klzig
Actualizado 2021-06-15 14:09:28 UTC
Best I can tell from the cursory technical specs is that for the Sprite the backup for a custom (not smart) watering schedule is in the cloud and for the Spark the backup is stored on-device in nonvolatile memory.  Is this correct?
Ver: 3850   Respuesta: 1
klzig
Actualizado 2021-06-15 14:16:19 UTC
Ver: 3842   Respuesta: 1
Watering adjustment settings
Lyndon Whyatt
Actualizado 2021-06-15 16:55:38 UTC
Ver: 4109   Respuesta: 2
Actualizado 2021-06-16 14:03:50 UTC
Ver: 4249   Respuesta: 1
Jen Wells
Actualizado 2021-06-17 00:36:39 UTC
Ver: 4064   Respuesta: 1
System stuck on watering
Haris Eliades
Actualizado 2021-06-17 05:07:11 UTC
Ver: 4081   Respuesta: 2
Network error
Al Piscopo
Actualizado 2021-06-17 10:27:03 UTC
Ver: 3682   Respuesta: 1
Smart zone predictions?
Sid Smith
Actualizado 2021-06-17 12:12:33 UTC
Ver: 3979   Respuesta: 1
How to turn off Smart control
Riccardo Secco
Actualizado 2021-06-17 19:47:41 UTC
Ver: 4003   Respuesta: 1
