New lawn setting
Actualizado 2021-07-21 01:54:26 UTC
Ver: 4193   Respuesta: 1
Netro Pixie with Google Home
fauxserious
Actualizado 2021-07-21 19:50:41 UTC
What is the issue?
Ver: 4152   Respuesta: 1
Two electro valves activated at same time
Francesc Rodríguez
Actualizado 2021-07-21 20:07:01 UTC
Why is not possible two valves operating at the same time if the pump can be operate correctly?
Ver: 4325   Respuesta: 1
Connect to a network
James Yates
Actualizado 2021-07-22 21:08:14 UTC
Ver: 3600   Respuesta: 1
Keep Online
bechard
Actualizado 2021-07-24 11:09:25 UTC
Ver: 3585   Respuesta: 0
Strange Whisperer Acrtivity
Actualizado 2021-07-24 17:00:16 UTC
Ver: 4928   Respuesta: 5
Eric
Actualizado 2021-07-25 05:56:52 UTC
Ver: 3642   Respuesta: 1
Installing New Netro-6
Debby Plenert
Actualizado 2021-07-25 14:37:04 UTC
I removed an older controller and replicated the wiring when installing the new Netro.  Everything appears to be correct?  However, when watering is activated, the valves will fill up and vibrate or what not with water rushing internally.  But the sprinkler heads don’t pop up and no water comes out.  Any help here would be greatly appreciated.  Thanks!
Ver: 4494   Respuesta: 1
Rain sensor
Actualizado 2021-07-26 12:13:34 UTC
Ver: 4277   Respuesta: 1
Actualizado 2021-07-26 16:02:28 UTC
Ver: 4362   Respuesta: 2
David Farries
Actualizado 2021-07-28 02:11:18 UTC
Ver: 4243   Respuesta: 1
Moisture all day
Shai Amiel
Actualizado 2021-07-29 03:30:05 UTC
With smart schedule on, sometimes I see "moisture all day" sign to some zones.
What does it mean and what do the application do?
Shai
Ver: 4002   Respuesta: 1
no wifi connection mqtt blocked
Actualizado 2021-07-30 18:16:05 UTC
i received Netro programmer
no connection
i have a fritbox 7560
the server status message says
mqtt blocked port 1883
Ver: 4788   Respuesta: 1
Paco Gómez
Actualizado 2021-08-01 05:26:03 UTC
Un saludo
Ver: 3546   Respuesta: 1
Data out of the API
Jens Wymeersch
Actualizado 2021-08-01 13:24:46 UTC
Dear Netro,
Ver: 4146   Respuesta: 2
Just setup metro pixie.
mprtjd
Actualizado 2021-08-01 18:26:34 UTC
Ver: 3895   Respuesta: 2
Brian Brun
Actualizado 2021-08-03 02:40:17 UTC
Ver: 4026   Respuesta: 1
Weather Provider Error
Jacques
Actualizado 2021-08-03 22:26:44 UTC
Ver: 4261   Respuesta: 2
One zone not working
S Yarrish
Actualizado 2021-08-06 00:50:19 UTC
Ver: 3922   Respuesta: 1
Francesco G
Actualizado 2021-08-08 17:24:19 UTC
Ver: 3669   Respuesta: 1
