Smart things?
S D
Updated at 2020-06-01 23:14:05 UTC
View: 5350   Answer: 0
Missing Whisperer
guags99
Updated at 2020-05-29 18:11:36 UTC
This season when I put my whisperer back out to monitor my garden bed I looked on the app and no longer saw that device. So I went through the process to re-add it to my network and my Netro account and I get an error message stating that that serial number is already registered.  Anyone have any thoughts on how I can de-register and re-register this device?  Thanks
View: 8298   Answer: 1
Jesse For
Updated at 2020-05-29 08:33:36 UTC
View: 5759   Answer: 1
baijuviswam
Updated at 2020-05-28 18:56:02 UTC
View: 5674   Answer: 1
Delay between zones
Nicholas Lydakis
Updated at 2020-05-28 15:39:00 UTC
View: 5910   Answer: 1
Web interface
Emanuele Floridia
Updated at 2020-05-27 16:58:10 UTC
View: 6356   Answer: 1
Updated at 2020-05-25 16:08:09 UTC
View: 6052   Answer: 1
Is a full time wifi connection required for watering? Or any other unattended modes of failure?
Chris Graham
Updated at 2020-05-24 20:43:23 UTC
If wifi is disrupted will the controller continue to water acording to the most recently programmed schedules?
More generally are there any modes of failure (other than loss of power to the house) where the controller can unexpectedly halt watering?  It would be unacceptable to have one's garden die from lack of water if the system fails when one is away from home for a number of days.
View: 7868   Answer: 1
Chris Graham
Updated at 2020-05-24 20:37:39 UTC
View: 6581   Answer: 1
Pressure compensated drip hose
Simon Clark
Updated at 2020-05-24 17:22:21 UTC
I use Netafin pressure compensated drip hose on all my beds and there doesn’t seem To be an irrigation type for that. Is it OK using the drip setting which seems to be for micro drippers.
View: 8680   Answer: 0
Rearranging zones?
Kurt H
Updated at 2020-05-23 19:17:20 UTC
View: 6631   Answer: 1
Wayne Richards
Updated at 2020-05-23 16:07:26 UTC
View: 6145   Answer: 1
Roman Prochazka
Updated at 2020-05-22 07:55:46 UTC
Many thanks for early answer
Best Regards
Roman
View: 6604   Answer: 2
Best settings for garden
Alexandre Morin
Updated at 2020-05-20 11:01:20 UTC
thanks
View: 6927   Answer: 2
Kobus Marneweck
Updated at 2020-05-19 03:33:33 UTC
View: 6195   Answer: 1
Pixie sync Sprite
Sebastian Diaz
Updated at 2020-05-19 02:50:59 UTC
Thanks you Sebastian
View: 6595   Answer: 1
Watering program
Maciej Karpinski
Updated at 2020-05-18 01:01:57 UTC
View: 7452   Answer: 1
Yves Desrosiers
Updated at 2020-05-17 18:31:27 UTC
Thanks for your help :)
View: 6207   Answer: 1
EASTBOBDAM D
Updated at 2020-05-17 13:18:19 UTC
Thanks in advance
View: 5841   Answer: 1
Server upgrade scheduled on May 16th between 8:30PM and 9:00PM (Pacific Time)
Updated at 2020-05-17 03:23:28 UTC
To all Netro customers:
Due to rapid increase of active devices connected to the Netro cloud server, we are going to upgrade our server on May 16th Saturday night from 8:30PM to 9:00PM (Pacific Time). During that time frame, all cloud service will be temporarily unavailable but your watering schedules will run normally. If you have a smart watering controller, the light on the unit will blink fast.
View: 10736   Comment: 0
