Jesse For
Updated at 2020-05-29 08:33:36 UTC
View: 7395   Answer: 1
baijuviswam
Updated at 2020-05-28 18:56:02 UTC
View: 7354   Answer: 1
Delay between zones
Nicholas Lydakis
Updated at 2020-05-28 15:39:00 UTC
View: 7631   Answer: 1
Web interface
Emanuele Floridia
Updated at 2020-05-27 16:58:10 UTC
View: 8147   Answer: 1
Updated at 2020-05-25 16:08:09 UTC
View: 7752   Answer: 1
Is a full time wifi connection required for watering? Or any other unattended modes of failure?
Chris Graham
Updated at 2020-05-24 20:43:23 UTC
If wifi is disrupted will the controller continue to water acording to the most recently programmed schedules?
More generally are there any modes of failure (other than loss of power to the house) where the controller can unexpectedly halt watering?  It would be unacceptable to have one's garden die from lack of water if the system fails when one is away from home for a number of days.
View: 9624   Answer: 1
Chris Graham
Updated at 2020-05-24 20:37:39 UTC
View: 8292   Answer: 1
Pressure compensated drip hose
Simon Clark
Updated at 2020-05-24 17:22:21 UTC
I use Netafin pressure compensated drip hose on all my beds and there doesn’t seem To be an irrigation type for that. Is it OK using the drip setting which seems to be for micro drippers.
View: 10629   Answer: 0
Rearranging zones?
Kurt H
Updated at 2020-05-23 19:17:20 UTC
View: 8350   Answer: 1
Wayne Richards
Updated at 2020-05-23 16:07:26 UTC
View: 7819   Answer: 1
Roman Prochazka
Updated at 2020-05-22 07:55:46 UTC
Many thanks for early answer
Best Regards
Roman
View: 8433   Answer: 2
Best settings for garden
Alexandre Morin
Updated at 2020-05-20 11:01:20 UTC
thanks
View: 8642   Answer: 2
Kobus Marneweck
Updated at 2020-05-19 03:33:33 UTC
View: 7825   Answer: 1
Pixie sync Sprite
Sebastian Diaz
Updated at 2020-05-19 02:50:59 UTC
Thanks you Sebastian
View: 8395   Answer: 1
Watering program
Maciej Karpinski
Updated at 2020-05-18 01:01:57 UTC
View: 9138   Answer: 1
Yves Desrosiers
Updated at 2020-05-17 18:31:27 UTC
Thanks for your help :)
View: 7914   Answer: 1
EASTBOBDAM D
Updated at 2020-05-17 13:18:19 UTC
Thanks in advance
View: 7438   Answer: 1
Server upgrade scheduled on May 16th between 8:30PM and 9:00PM (Pacific Time)
Updated at 2020-05-17 03:23:28 UTC
To all Netro customers:
Due to rapid increase of active devices connected to the Netro cloud server, we are going to upgrade our server on May 16th Saturday night from 8:30PM to 9:00PM (Pacific Time). During that time frame, all cloud service will be temporarily unavailable but your watering schedules will run normally. If you have a smart watering controller, the light on the unit will blink fast.
View: 12734   Comment: 0
Link to smart light
Noam Leshem
Updated at 2020-05-16 17:53:06 UTC
View: 8032   Answer: 1
No 2.4GHz wifi
Carlos Oliveira
Updated at 2020-05-16 11:29:24 UTC
My netro has been working fine for the past many months.
Suddenly it stopped working and light blinks.
I try to configure the Wifi again and it states
I am sure my 2.4 GHz network is available there as I have 2 other devices 10 Cm away from the netro and are working fine at 2.4GHz
I can confirm that in my Orbi Router.
Any ideas ?
Carlos
View: 10783   Answer: 1
