Default rain settings
jbart65
Updated at 2020-05-12 21:31:24 UTC
View: 7609   Answer: 1
where is the rst button
Jennml
Updated at 2020-05-12 18:00:51 UTC
View: 7093   Answer: 1
Smart Watering Adjustment
Tarudro
Updated at 2020-05-11 20:56:22 UTC
Hi Guys,
Kind regards & stay healthy,
Lukas
View: 7785   Answer: 2
Unit system
Andrea DiPi
Updated at 2020-05-10 08:11:33 UTC
Gooooddddmoooooorning!
Here where we are!!! Torino - Cincinnati - Alice Sping - Skagen - Macao - ......
Is it possible set the app whit a unit as metric or imperial or...Mars?!? It is very boring that some parameters are in metric an other in sqft x ex.
View: 9486   Answer: 1
Chen Li
Updated at 2020-05-10 05:45:08 UTC
View: 6977   Answer: 1
Pixie Pending
Rich Keith
Updated at 2020-05-09 19:07:11 UTC
View: 7129   Answer: 2
2 different water sources
Carlos Oliveira
Updated at 2020-05-09 14:51:27 UTC
I have the netro connected to one water source.
Now I am going to install a vertical garden with very low flow and I want the source of water to be a different one from the main source for the garden.
Is there a way I can connect it as an independent solenoide valve that doesn't need to have the master turned on ?
Carlos
View: 10180   Answer: 1
Suited for exterio?
Joan Peiro
Updated at 2020-05-09 01:50:15 UTC
View: 7500   Answer: 2
alnavasa
Updated at 2020-05-08 20:36:44 UTC
Start ar 21:00 end at 3am
View: 10945   Comment: 0
Andrea Merito
Updated at 2020-05-08 07:20:50 UTC
hello,
Andrea
View: 7294   Answer: 1
Kevin Tung
Updated at 2020-05-07 21:55:00 UTC
View: 6984   Answer: 1
alnavasa
Updated at 2020-05-07 21:51:54 UTC
View: 7690   Answer: 1
alnavasa
Updated at 2020-05-07 21:49:17 UTC
Feature request:
View: 7658   Answer: 2
Master valve
Sasha Obradovic
Updated at 2020-05-07 20:56:46 UTC
View: 7689   Answer: 1
Discover your garden
Updated at 2020-05-07 16:16:29 UTC
Not only the last 12 months
View: 7528   Answer: 1
Weston Hull
Updated at 2020-05-07 14:52:41 UTC
View: 7219   Answer: 1
Whisperer Changing Colors
Patrick
Updated at 2020-05-06 02:32:37 UTC
My Netro Whisperer sensor LED changed colors from blue to red on its own.  Is this normal?
View: 7134   Answer: 1
How to delete Smart Schedule?
Matty Moe
Updated at 2020-05-06 01:35:06 UTC
View: 7115   Answer: 1
Whisper wifi strength?
Weston Hull
Updated at 2020-05-05 17:29:53 UTC
Is there a way to see the wifi strength from the sensor.   From the phone I have good strength but from as far as the sensor it comes and goes for reporting.   Thanks!
View: 8341   Answer: 0
Nomi zone e comandi alexa
Mirko Paganelli
Updated at 2020-05-05 06:26:19 UTC
View: 7346   Answer: 1
