Offline buy watered
Haris Eliades
Updated at 2020-11-09 06:22:11 UTC
View: 7319   Answer: 1
Curt Lizzi
Updated at 2020-11-03 18:41:08 UTC
Am I doing something wrong?
Curt
View: 7712   Answer: 1
dinzdale
Updated at 2020-11-03 16:00:28 UTC
View: 7186   Answer: 1
Didn’t water. Exclamation point inside of triangle
Updated at 2020-11-03 11:05:39 UTC
Controller didn’t turn on sprinklers at 0400hrs today.  Instead schedule shows yellow triangle with exclamation symbol, but gives no breakdown on why system didn’t turn on water.  If controller shows exclamation, it would be nice if it showed an actual description of problem/event.
View: 9643   Answer: 1
Add zones manually in queue
Haris Eliades
Updated at 2020-11-03 04:04:49 UTC
View: 7452   Answer: 1
How do I turn off for Winter?
Paul A
Updated at 2020-10-30 20:59:47 UTC
View: 7165   Answer: 2
New user
Haris Eliades
Updated at 2020-10-28 20:35:38 UTC
Hello!
Zone 4, 2 minutes
Zone 5, 2 minutes
Zone 1, 4 minutes
Zone 2, 4 minutes
Zone 3, 4 minutes
Zone 4, 4 minutes
Zone 5, 2 minutes
View: 7248   Answer: 1
Stefan Pena
Updated at 2020-10-25 10:41:41 UTC
Hey guys!
View: 7044   Answer: 1
Email address length
Alberto Castro Hinojosa
Updated at 2020-10-24 21:37:57 UTC
Could you review please?
View: 8681   Answer: 1
David Farries
Updated at 2020-10-24 20:24:40 UTC
View: 7494   Answer: 1
Manually entering rainfall
Curt Lizzi
Updated at 2020-10-17 13:16:09 UTC
View: 7570   Answer: 1
Problem With application
Alex Guerrero
Updated at 2020-10-17 08:21:08 UTC
View: 7171   Answer: 1
Netro unit
Bhumit Joshi
Updated at 2020-10-16 18:15:51 UTC
I just got my system winterized today. Netro box is still on. Do i just unplug it for the winter?
View: 8583   Answer: 1
"Next in" shows "--"
Luis Aguilar
Updated at 2020-10-14 18:45:01 UTC
View: 7172   Answer: 1
How stop 1 day
Leonardo Antonucci
Updated at 2020-10-11 18:33:55 UTC
View: 7085   Answer: 1
Questions about Netro app
Luis Aguilar
Updated at 2020-10-11 17:47:55 UTC
View: 7315   Answer: 1
Simone Nolletti
Updated at 2020-10-11 11:46:06 UTC
Buonasera,
View: 7850   Answer: 1
Switch Off automatically
Carlos Jimenez
Updated at 2020-10-09 20:18:31 UTC
I found two cases,
View: 7150   Answer: 1
OFFLINE
Javier López-Guerrero
Updated at 2020-10-03 08:20:26 UTC
Help!
Javier
View: 7082   Answer: 2
Atif Khan
Updated at 2020-10-01 14:21:57 UTC
View: 7116   Answer: 1
