Not enough watering time
Homestead One
Updated at 2020-07-08 20:04:00 UTC
I have 4 zones activated.
Please help.
View: 4289   Answer: 1
JanT
Updated at 2020-07-08 18:44:04 UTC
View: 4060   Answer: 1
Arthur
Updated at 2020-07-08 16:08:19 UTC
View: 3969   Answer: 1
Andrea Merito
Updated at 2020-07-08 07:15:38 UTC
thank you
Andrea
View: 4271   Answer: 1
Jim Falvey
Updated at 2020-07-07 23:54:23 UTC
View: 4256   Answer: 1
Battery status
Francis Ramos
Updated at 2020-07-07 15:07:47 UTC
View: 3952   Answer: 1
Hozelock
Alan George
Updated at 2020-07-06 18:50:08 UTC
View: 4066   Answer: 1
Add solenoid valves
thái bình dương
Updated at 2020-07-06 17:01:57 UTC
hi netro
I have 48 solenoid valves and I want to connect 3 valves to 1 zone of the sprite kit, each valve has a capacity of 3w. Thank you
View: 4059   Answer: 1
sw238
Updated at 2020-07-05 15:42:38 UTC
View: 4055   Answer: 1
Michael Fortwengler
Updated at 2020-07-04 19:06:14 UTC
View: 4022   Answer: 1
Brendan Burke
Updated at 2020-07-04 14:38:40 UTC
View: 4281   Answer: 1
Updated at 2020-07-04 13:11:16 UTC
Zone 1-11 minutes each run
Zone 2-11 minutes each run
Zone 3-06 minutes each run
Zone 7-06 minutes each run
View: 4266   Answer: 1
Connessione wifi problematica
Emanuele Floridia
Updated at 2020-07-03 17:32:30 UTC
Buonasera a tutti,
C’è un rimedio?
View: 3931   Answer: 0
low water pressure
vic sabo
Updated at 2020-07-02 22:08:39 UTC
View: 4145   Answer: 1
Vision
Art Brownlee
Updated at 2020-07-02 01:24:34 UTC
View: 3753   Answer: 1
Text Colour un IOS App
Ignacio Sánchez
Updated at 2020-06-30 08:41:30 UTC
Any suggestion about ?
Thanks  in Advance.
View: 3921   Answer: 2
Power Cycle
Jorge Bastos
Updated at 2020-06-26 22:30:53 UTC
Any way to correct this?
Regards.
View: 4099   Answer: 1
Igor
Updated at 2020-06-25 14:27:46 UTC
View: 3978   Answer: 1
Rob and Susan Tartre
Updated at 2020-06-24 20:13:25 UTC
Thank you for any help!!
View: 4724   Answer: 3
60 minutes maximum, problem
Brendan Burke
Updated at 2020-06-24 00:36:59 UTC
View: 4435   Answer: 1
