60 minute limit
C S
Updated at 2021-06-01 21:33:39 UTC
View: 6911   Answer: 1
Sensor inputs
Updated at 2021-06-01 11:33:16 UTC
View: 7585   Answer: 1
UK watering restrictions
Updated at 2021-06-01 11:26:19 UTC
Cheers,
Andy
View: 11934   Answer: 1
Mancata irrigazione
Cristian Toraldo
Updated at 2021-06-01 05:47:43 UTC
Buongiorno ogni volta che salta la corrente la centralina crede di funzionare ma gli irrigatori non partono. Per far sì che tutto riprenda a funzionare bisogna ogni volta resettare la centralina ma se qualcuno è via per molto tempo potrebbe costituire un grosso problema.
View: 8443   Answer: 1
Sign it
Matthew Gruen
Updated at 2021-06-01 00:50:47 UTC
View: 7302   Answer: 1
Wi-Fi connectivity
saketshah
Updated at 2021-05-31 21:20:22 UTC
Appreciate your help.
View: 8453   Answer: 1
Completely ater
Updated at 2021-05-31 20:03:22 UTC
View: 7582   Answer: 1
Yuriy Andamasov
Updated at 2021-05-31 19:44:41 UTC
Thanks in advance.
View: 7176   Answer: 1
Wisperer not working
Andrea Paparotti
Updated at 2021-05-31 14:42:20 UTC
View: 9350   Answer: 2
Pedro Abad
Updated at 2021-05-30 08:33:28 UTC
Thank you all!
View: 7482   Answer: 2
Pedro Abad
Updated at 2021-05-30 08:18:01 UTC
Thanks and best regards
View: 8625   Answer: 1
Updated at 2021-05-28 19:17:48 UTC
View: 9500   Answer: 1
Douglas Peale
Updated at 2021-05-28 02:59:54 UTC
View: 8520   Answer: 1
Douglas Peale
Updated at 2021-05-27 22:32:59 UTC
View: 7379   Answer: 1
banaszar
Updated at 2021-05-25 17:23:58 UTC
View: 6954   Answer: 2
Connect one whisperer to two pixies
jmkluft
Updated at 2021-05-24 14:14:03 UTC
For the moment, I have one whisperer connected to one pixie, and everything is working fine.
I have a question though, if I would add another pixie to control another watering zone, can I connect the same whisperer to that second pixie?
In other words, can I connect one whisperer to two pixies?
Thx,
JM
View: 8646   Answer: 1
Brad Grizzly
Updated at 2021-05-23 03:42:20 UTC
View: 6859   Answer: 1
Sensor usage
Ilya Lifshits
Updated at 2021-05-22 08:17:29 UTC
Hi ,
Ilya
View: 8478   Answer: 1
Learning
John Conley
Updated at 2021-05-21 12:05:43 UTC
View: 8316   Answer: 1
Mitch Green
Updated at 2021-05-20 22:11:37 UTC
View: 8887   Answer: 1
