Netro Pixie with Google Home
fauxserious
Updated at 2021-07-21 19:50:41 UTC
What is the issue?
View: 7590   Answer: 1
New lawn setting
Updated at 2021-07-21 01:54:26 UTC
View: 7815   Answer: 1
BaiPhillips
Updated at 2021-07-20 20:42:15 UTC
View: 7287   Answer: 2
Not all zones are executing
Brian Brun
Updated at 2021-07-20 14:19:47 UTC
View: 7817   Answer: 1
Ramón Rivero
Updated at 2021-07-20 08:32:53 UTC
View: 7234   Answer: 1
Pixie and Whisperer
Nick Thoman
Updated at 2021-07-19 17:46:37 UTC
View: 7527   Answer: 1
Barry Litinsky
Updated at 2021-07-18 23:12:56 UTC
View: 6766   Answer: 1
wwhitfill
Updated at 2021-07-18 13:52:07 UTC
View: 8497   Answer: 2
Default view on startup
Addiel Isaac Moldes
Updated at 2021-07-18 12:45:53 UTC
View: 7371   Answer: 1
Addiel Isaac Moldes
Updated at 2021-07-18 12:42:37 UTC
It was or wasn't included?
View: 7395   Answer: 1
Internet down
Updated at 2021-07-18 11:38:25 UTC
View: 8942   Answer: 2
Jcraft200
Updated at 2021-07-18 02:44:57 UTC
I get to set 3 set up wifi
TIA
View: 7497   Answer: 4
New system won’t work
acala768
Updated at 2021-07-16 13:30:59 UTC
What do I do.
View: 6673   Answer: 1
Weather Conditions setting
Steven Then
Updated at 2021-07-15 14:04:18 UTC
View: 8239   Answer: 1
New install problems
M A
Updated at 2021-07-14 23:07:34 UTC
View: 8778   Answer: 1
Nachomotos
Updated at 2021-07-14 07:00:23 UTC
Nacho
View: 8834   Answer: 1
No carga la bateria
JORDIBARBERA
Updated at 2021-07-12 14:11:15 UTC
View: 8367   Answer: 1
gbs-122
Updated at 2021-07-11 10:22:07 UTC
View: 8563   Answer: 2
Mike Willet
Updated at 2021-07-07 17:27:53 UTC
View: 6863   Answer: 1
Richard Richards
Updated at 2021-07-06 22:32:47 UTC
View: 6907   Answer: 1
