Second house
Dave Hornsey
Updated at 2020-09-29 18:20:51 UTC
I'm in the very fortunate position of having 2 homes - one in the UK and one in Spain. We've just had the garden reworked in the UK and I've been able to install an irrigation system controlled by a single Sprite controller.
I'm very pleased with how this is working - and now want to upgrade the manual irrigation system we have in our Spanish house to a smart system. Can Netrohome / the (Android) app manage 2 different irrigation systems in 2 different locations (with 2 very different climates)?
Many thanks.
View: 8650   Answer: 1
Controller LED Light
Texas AF
Updated at 2020-09-22 14:01:57 UTC
View: 7254   Answer: 1
HomeOwner
Isaac Fishman
Updated at 2020-09-21 01:14:55 UTC
View: 8415   Answer: 1
Multiple sprinklers in one zone - and is there a Test System ?
Cormac Champion
Updated at 2020-09-19 13:48:55 UTC
Can zones be setup with several sprinklers in the one zone ?  From what I can see from another question, is it correct that you setup the aproximate size of each zone ?  I have several zones with maybe 10 sprinklers in each zone, with sprinklers about 3m apart.
Also, is there any access to a test / simulation system that I can setup my location and see how well it would adapt to weather.  I am planning the installation for southern Spain
Thanks in advance
View: 7616   Answer: 1
Simple on/off
gmcg1984
Updated at 2020-09-17 01:54:35 UTC
View: 7100   Answer: 1
Contact
Santiago Errazuriz
Updated at 2020-09-16 14:44:36 UTC
Hello good morning, greetings from Chile. I need to know if I can have a whatsapp or contact email.
View: 8407   Answer: 1
Start time change
Franco Storato
Updated at 2020-09-16 06:00:59 UTC
Thank you in advance,
Franco
View: 6907   Answer: 1
loose connection on install
Lawrence Jones
Updated at 2020-09-15 22:49:22 UTC
The unit is working good, yeah!  The way the wires get tab/push for contact is really cheap.  The "spring" of the contact is very , very loose.
Move the wire at all and no contact.  Then trouble shooting to find where trouble is.  Not a good design. Need a much more firm grip on the bare wire. something else or just poor quality?
View: 8733   Answer: 1
Potted plant on terrace
Andrea Zorgniotti
Updated at 2020-09-14 07:46:03 UTC
Hi I Have a big terrace with many plants divided in 3 zone controlled by Netro. To use the smart watering and have an acceptable time/frequence for watering (6 min every 2.5 days) I have to set user and from 80% to 85% umidity. If I set frequent or extra water the estimated frequency is 4/5 days. Considering in summer my setting seems nor giving enough water to plants what kind of setting do you suggest to increase the frequency (change msq, kind of sprinkle or whatever).
Thanks in advance for answer
View: 7533   Answer: 1
Way to add weather stations
Curt Lizzi
Updated at 2020-09-12 01:16:55 UTC
I find the Weather apps to be very inaccurate with respect to rainfall at my home. Is there a way to add a near by weather station for better accuracy?
View: 7629   Answer: 1
IFTTT - Watering Schedule
Updated at 2020-09-10 05:56:28 UTC
Thanks in advance,
View: 7714   Answer: 1
Rain Snow Delay
R H
Updated at 2020-09-10 03:35:37 UTC
View: 7277   Answer: 1
Shut down for winter
Chad Fuller
Updated at 2020-09-10 02:01:10 UTC
View: 7945   Answer: 1
Netro and Google home
Cesar
Updated at 2020-09-08 08:26:17 UTC
HI
Could you please help
View: 6852   Answer: 1
Temporarily stop all watering
Williams
Updated at 2020-09-07 15:57:32 UTC
How do I temporarily stop all watering without losing the programming?
View: 8628   Answer: 1
Remove Plant Sensor dropdown
Scott McKay
Updated at 2020-09-05 21:09:40 UTC
View: 6980   Answer: 1
controller kept go offline
Updated at 2020-09-05 01:12:13 UTC
Hello, wondering why my watering controller kept going offline.  Once turning it off/on, it will goes online again but will go off in several hours later.  Is it time for me to get a new controller?  I hope not
View: 9665   Answer: 2
Sensor watering adjustment doesn't work - bug
Roman Stanek
Updated at 2020-09-04 04:49:34 UTC
I installed two sensors today and added watering adjustment so that every time the humidity goes below 10% another 10 minutes of watering is added. Unfortunately, there is a bug and the watering time is triggered right away even though the faucet timer connects only every three hours. The additional watering time needs to be scheduled after the next timer sync and not right away. It's a clear bug.
View: 7270   Answer: 1
Whisper sensor
Randle Griffin
Updated at 2020-09-03 04:18:11 UTC
View: 6954   Answer: 1
Email too long in android app
Christoforos
Updated at 2020-09-02 09:49:14 UTC
View: 7252   Answer: 1
