Pixie linked to 2 iphone
Paolo S
更新時間 2023-04-10 13:29:30 UTC
Is it possible to control 1pixie with 2 iphone?
瀏覽: 3511   回覆: 1
Phone number
Graham Corrett
更新時間 2023-04-05 13:07:22 UTC
Does anyone I have a contact/help number for this company possibly in the UK I’ve sent an email but no response!
瀏覽: 3540   回覆: 1
Sprinklers not going off per schedule
Brian Brun
更新時間 2023-03-28 22:50:06 UTC
What are my sprinklers not going off per schedule? I have a schedule that it supposed to kick off Tuesday and Thursday. It is set to start at 6:00. It is 6:50 and it has not went off. I just had to manually run a cycle.
瀏覽: 3673   回覆: 1
No wifi connection
gdimofte@gmail.com
更新時間 2023-03-27 18:00:53 UTC
Dear Sir
Gabriel
瀏覽: 3372   回覆: 1
Shedule
jmgrau
更新時間 2023-03-09 07:21:43 UTC
How can I program the app so that it does not do automatic shedule watering, only those programmed manually, I only want the gespa dalt and gespa baix dryers to irrigate 1 minute a day.
瀏覽: 3493   回覆: 1
Vincent Coutinho
更新時間 2023-02-18 16:26:02 UTC
瀏覽: 4872   評論: 2
MEANING OF code E2
balvant patel
更新時間 2023-02-02 16:06:49 UTC
What is E2 means?
Pl. reply ASAP
Patel
瀏覽: 3532   回覆: 1
Whisperer light
更新時間 2023-02-01 09:56:18 UTC
What should I do ?
瀏覽: 3668   回覆: 1
Jim Barnes
更新時間 2023-01-25 13:36:55 UTC
Please help!!!
瀏覽: 3725   回覆: 2
Change Username
Casa Luna
更新時間 2023-01-13 10:08:35 UTC
Is it possible?
Thanks in advance :)
瀏覽: 3335   回覆: 1
Home Assistant
Jens Wymeersch
更新時間 2023-01-12 09:25:04 UTC
瀏覽: 4335   回覆: 2
更新時間 2022-12-26 09:03:17 UTC
瀏覽: 3721   回覆: 1
Irrigazione incontrollata
Martina Brasesco
更新時間 2022-12-22 15:13:34 UTC
Salve,
瀏覽: 3490   回覆: 1
Roberto Felici
更新時間 2022-12-11 13:31:01 UTC
Ciao!
Tx!
瀏覽: 3544   回覆: 1
Netro Plugin for Jeedom
更新時間 2022-11-30 22:07:13 UTC
Hello guys,
kcofoni
瀏覽: 5175   評論: 1
Defective Whisperer
更新時間 2022-11-26 10:04:00 UTC
瀏覽: 3853   回覆: 1
Network error
Sadar Yacob
更新時間 2022-11-25 15:04:34 UTC
瀏覽: 4296   回覆: 2
Random manual runs in the log
Ilya Lifshits
更新時間 2022-11-20 12:36:44 UTC
Hello ,
How it be fixed ?
Ilya
瀏覽: 3547   回覆: 1
Sprite 6 will not connect
Robert Christel
更新時間 2022-11-19 18:45:59 UTC
Bob
瀏覽: 3558   回覆: 1
Manual Mode not working
Gary C
更新時間 2022-11-08 23:30:48 UTC
瀏覽: 3779   回覆: 2
