更新時間 2023-11-07 13:27:20 UTC
瀏覽: 36312   評論: 1
Why did the schedule run went it’s raining
Scott Flanigan
更新時間 2023-10-26 19:00:19 UTC
Why did my system run while we are having constant rain and flood alerts
瀏覽: 3875   回覆: 1
The app is full of useless things
MB
更新時間 2023-10-19 17:08:43 UTC
MAKE IT SIMPLE AND FAST!
- not possible to run multiple valve at the same time
- app and webapp full of useless things such as the BIG clock in the schedule attached
- interface full of too many things. I dont care about smart watering. why my screen should be full of that?
- setting full of useless things.
- apps should be fast and simple, if you focus on professionals. If you focus on housewives is another story.
- example of ewelink
- not possible to run all the time you want. max 60 minutes. Edit program full of things again.
- under zone there should be the possibility to add the schedule. why you are making an extra menu?? Zone 1 --> prog1 -->start h8.00; finish h.10:00
瀏覽: 3979   回覆: 1
Terrible product?
Andrew Martin
更新時間 2023-10-16 14:26:31 UTC
Three hours to setup
瀏覽: 4010   回覆: 2
Alexa Skill
Louise Brinkman
更新時間 2023-10-13 01:00:17 UTC
瀏覽: 4449   評論: 3
Linking Google Home to Netro
cadry1969
更新時間 2023-10-07 03:21:23 UTC
瀏覽: 3711   回覆: 2
Schedule
Jim Lacy
更新時間 2023-09-28 02:00:48 UTC
瀏覽: 3768   回覆: 1
My device is offline
carlos davalos melgar
更新時間 2023-09-17 18:50:32 UTC
How can I reconnect to Wi-Fi
the controller light is green
Please i need help
瀏覽: 3890   回覆: 1
Change Wifi problem
Luciani Daniele
更新時間 2023-09-12 15:54:28 UTC
瀏覽: 3577   回覆: 1
Scheduling Issue
Steve Loesch
更新時間 2023-09-12 13:59:31 UTC
First.
Second.
瀏覽: 3715   回覆: 1
Whisperer stake cracked
更新時間 2023-09-09 20:22:46 UTC
瀏覽: 3821   回覆: 1
Arghhh, so horrible
Jake Tanner
更新時間 2023-09-09 16:24:29 UTC
瀏覽: 3708   回覆: 1
smart watering
Diane Fetherolf
更新時間 2023-09-04 22:29:30 UTC
瀏覽: 3385   回覆: 1
Sensor offline
Tonycimo
更新時間 2023-08-28 21:29:20 UTC
How csn i solve it?
Czn i check snything?
瀏覽: 3496   回覆: 1
Not connecting
Ali M
更新時間 2023-08-27 05:07:14 UTC
瀏覽: 3458   回覆: 1
Xavi
更新時間 2023-08-25 21:23:22 UTC
瀏覽: 3403   回覆: 0
Jacob Matheny
更新時間 2023-08-22 15:15:10 UTC
瀏覽: 3620   回覆: 1
Jacob Matheny
更新時間 2023-08-22 15:14:09 UTC
瀏覽: 3647   回覆: 0
Aspensprinklers
更新時間 2023-08-13 23:37:32 UTC
瀏覽: 3501   回覆: 1
C He
更新時間 2023-08-13 11:54:36 UTC
Whats wrong?
瀏覽: 3708   回覆: 1
