Mike Carey
更新時間 2025-03-02 17:48:24
瀏覽: 880   回覆: 1
Door came off the unit
Michael Riley
更新時間 2025-02-19 19:52:51
瀏覽: 934   回覆: 1
W4MSolutions
更新時間 2025-01-23 17:32:49
瀏覽: 1251   回覆: 1
Pixie - Z1
Steve Inwood
更新時間 2025-01-16 10:10:53
瀏覽: 1159   回覆: 1
Trevor Pfeiffer
更新時間 2024-12-26 20:05:12
Trevor Pfeiffer
瀏覽: 1267   回覆: 1
John BAIMAY
更新時間 2024-12-26 11:35:25
Regards.
瀏覽: 1289   回覆: 1
Sprite / Spark and Flume
Bruce P
更新時間 2024-12-12 22:28:13
Thinking of scenarios like:
瀏覽: 1297   回覆: 1
Carolyn Simmons
更新時間 2024-12-01 20:53:00
瀏覽: 1334   回覆: 1
Andrea DS
更新時間 2024-11-27 21:01:38
瀏覽: 1342   回覆: 1
Konrad
berlin
更新時間 2024-11-10 09:36:28
Who can help me?
Thank's
Konrad
瀏覽: 1461   回覆: 1
Conrtoler
John Zuzula
更新時間 2024-10-19 23:45:24
瀏覽: 1554   回覆: 1
Manual mode without delay
Phil Houghton
更新時間 2024-10-04 23:27:59
瀏覽: 1585   回覆: 1
How do I?
Rockhead413
更新時間 2024-10-01 00:08:51
Vincent Devlahovich
805-813-1216
Loyal customer
瀏覽: 1659   回覆: 1
更新時間 2024-09-19 03:30:21
瀏覽: 19081   評論: 3
Ac adaptor
Cisco -
更新時間 2024-08-24 21:45:58
瀏覽: 1910   回覆: 1
Van Klaveren Patrick
更新時間 2024-08-15 10:04:53
瀏覽: 2020   回覆: 1
Smart watering very stupid
Ruth Wengert
更新時間 2024-08-13 14:22:33
瀏覽: 2047   回覆: 1
Terminal 1 not working
Morgans_Home
更新時間 2024-08-12 01:27:03
瀏覽: 2065   回覆: 1
Sensor plat
Tiago Lourenco
更新時間 2024-07-28 12:17:00
Good afternoon
I have plant sensors in all zones, and they block.
Sometimes i have my grass really dry and the sensor have 70/80 % of humidity.
I turn them off change place like 2 cm, turn them in again and they have the correct humidity.
Anyone experience this?
Thank you in advance
瀏覽: 2317   回覆: 3
Metro timer
Anne McNamara
更新時間 2024-07-04 13:16:31
Everything shows it should be running, but it doesn’t wake up. I have it set for online during watering periods. It says it’s communicating but it’s not running. How do I wake up metro when I want to communicate
瀏覽: 2220   回覆: 1
