Whisper 2 problems
Phil Middleton
更新時間 2024-05-20 09:13:29 UTC
瀏覽: 2203   回覆: 1
Compatibilità con Smartthings
Farina Vincenzo
更新時間 2024-05-18 20:44:01 UTC
瀏覽: 2173   回覆: 1
Antonio Cordon Rodriguez
更新時間 2024-05-08 18:57:57 UTC
Hello.
I have a wishperer sensor in my garden and the measured values, in my opinion, are not correct in the following hours when the garden is watered. I have seen this same problem on other occasions. Is it possible to check it? Thank you very much.
The figure shows an example (the garden is watered at 6am):
瀏覽: 2236   回覆: 1
No LED
Derek Barss
更新時間 2024-05-02 04:24:35 UTC
There is no LED on my device.  I've power cycled on and off a few times and no change.
Strangely enough it shows connected to wifi but not starting water on a manual test.
Is it dead?
瀏覽: 2351   回覆: 2
Netro Pixie Z1 Connection Issues to Hub - Please Help
Nicholas Cole
更新時間 2024-04-28 15:58:10 UTC
I have a Netro Pixie Z1 hose timer in my garden, which is about 50 feet away from its hub. I’ve been dealing with connection issues (routinely disconnecting from the app and randomly stopping watering schedules), which is strange because there are no obstructions between the timer and the hub, and it is a fairly short distance. When standing by the timer, I can clearly
see the hub in my window. I have the hub plugged into the back of my WiFi router via an Ethernet cable, so WiFi connection is not the problem. The connection between the timer and the hub is. Does anybody have any suggestions on how to fix this problem? If I can’t get the Pixie Z1 to have a stable connection, I will have to buy a regular Pixie.
- Nick
瀏覽: 2268   回覆: 1
Programs
Roberto Pirovano
更新時間 2024-04-06 16:31:34 UTC
瀏覽: 2172   回覆: 0
Potted Pkants
更新時間 2024-03-21 20:24:24 UTC
Wency,
Houston. Texas
瀏覽: 2439   回覆: 1
Rain delay error
David Maerzke
更新時間 2024-02-23 20:51:22 UTC
I'm getting "Error: Rain delay 1039728 with an end date of 2024-02-27."  I want to extend the delay, but it won't let me.
瀏覽: 2423   回覆: 1
Set up with mobile phone hotspot
Paul_D
更新時間 2024-02-20 07:56:42 UTC
Hi I am going to install a sprite controller at a property before wifi is installed.
Can I set up programs on the controller using hotspot from my phone? So it can then use the irrigation schedule in offline mode until I can connect to wifi.
瀏覽: 2305   回覆: 1
Connecting to Wi-Fi
Linda Lopez
更新時間 2024-02-07 16:08:44 UTC
I've had Netro for 3 years I changed my wifi and I updated it my app. It worked for a couple of weeks and all of a sudden it stopped working. I can't get it to connect to the wifi. It says offline. I can't even do a manual run. Does anyone have any suggestions?
瀏覽: 2395   回覆: 1
Istruzioni
Alexxxx
更新時間 2024-02-05 20:31:47 UTC
Dove trovo le istruzioni perla programmazione Dell app in Italiano?
瀏覽: 2300   回覆: 1
Thresholds
Shady Trails
更新時間 2023-12-23 16:16:15 UTC
瀏覽: 2814   評論: 3
Netro delivery
buggs
更新時間 2023-12-16 23:16:36 UTC
瀏覽: 2471   回覆: 1
Spark not working
Mick Faulks
更新時間 2023-11-26 07:04:12 UTC
瀏覽: 2606   回覆: 1
Scott Flanigan
更新時間 2023-11-10 17:04:48 UTC
瀏覽: 2742   回覆: 2
更新時間 2023-11-07 13:27:20 UTC
瀏覽: 33091   評論: 1
Why did the schedule run went it’s raining
Scott Flanigan
更新時間 2023-10-26 19:00:19 UTC
Why did my system run while we are having constant rain and flood alerts
瀏覽: 2666   回覆: 1
The app is full of useless things
MB
更新時間 2023-10-19 17:08:43 UTC
MAKE IT SIMPLE AND FAST!
- not possible to run multiple valve at the same time
- app and webapp full of useless things such as the BIG clock in the schedule attached
- interface full of too many things. I dont care about smart watering. why my screen should be full of that?
- setting full of useless things.
- apps should be fast and simple, if you focus on professionals. If you focus on housewives is another story.
- example of ewelink
- not possible to run all the time you want. max 60 minutes. Edit program full of things again.
- under zone there should be the possibility to add the schedule. why you are making an extra menu?? Zone 1 --> prog1 -->start h8.00; finish h.10:00
瀏覽: 2819   回覆: 1
Terrible product?
Andrew Martin
更新時間 2023-10-16 14:26:31 UTC
Three hours to setup
瀏覽: 2820   回覆: 2
Alexa Skill
Louise Brinkman
更新時間 2023-10-13 01:00:17 UTC
瀏覽: 3168   評論: 3
