WATER SCHEDULING / WEATHER INFORMATION UPDATE
Javier NM
更新時間 2024-05-26 06:49:27 UTC
First of all, I have been using my Sprite for one year, and the result is very positive. My lawn is better, and I have learnt about how watering should be done in my case. Congratulations to the Netro team. Let me add some questions below.
On 2023-06-13 Wency said "Netro sever side gets/ updates weather information every early morning at around 4 am.
If the weather forecast changes, Netro will update and recalculate the schedule." But could you expand what time zone is this 4 am?.
And a second question is: how often the system recalculates the watering scheduling after a programmed or manual watering? Will that go in the same refreshing as the weather info refreshing? also at 4 am?
瀏覽: 3415   回覆: 1
No Answers
Charles Currie
更新時間 2024-05-25 17:07:13 UTC
瀏覽: 3263   回覆: 1
mae winslow
更新時間 2024-05-24 02:05:23 UTC
瀏覽: 3263   回覆: 1
2 separate systems
Roger Johnston
更新時間 2024-05-22 19:07:12 UTC
We have a 9 zone lawn system and a seperate 4 zone garden system. The controllers are 100 yards apart. We hand 2 Netro controllers and a home network that covers the entire area. Can both controllers be operated with one same app? I’ve tried but without success….must be missing something.
瀏覽: 3262   回覆: 1
Weather Underground
LM90
更新時間 2024-05-22 16:23:22 UTC
Hi. The app wont let me add my wundergound id number (IRIBBE4). Can you please help
瀏覽: 3245   回覆: 1
Whisper 2 problems
Phil Middleton
更新時間 2024-05-20 09:13:29 UTC
瀏覽: 3426   回覆: 1
Compatibilità con Smartthings
Farina Vincenzo
更新時間 2024-05-18 20:44:01 UTC
瀏覽: 3331   回覆: 1
Antonio Cordon Rodriguez
更新時間 2024-05-08 18:57:57 UTC
Hello.
I have a wishperer sensor in my garden and the measured values, in my opinion, are not correct in the following hours when the garden is watered. I have seen this same problem on other occasions. Is it possible to check it? Thank you very much.
The figure shows an example (the garden is watered at 6am):
瀏覽: 3428   回覆: 1
No LED
Derek Barss
更新時間 2024-05-02 04:24:35 UTC
There is no LED on my device.  I've power cycled on and off a few times and no change.
Strangely enough it shows connected to wifi but not starting water on a manual test.
Is it dead?
瀏覽: 3540   回覆: 2
Netro Pixie Z1 Connection Issues to Hub - Please Help
Nicholas Cole
更新時間 2024-04-28 15:58:10 UTC
I have a Netro Pixie Z1 hose timer in my garden, which is about 50 feet away from its hub. I’ve been dealing with connection issues (routinely disconnecting from the app and randomly stopping watering schedules), which is strange because there are no obstructions between the timer and the hub, and it is a fairly short distance. When standing by the timer, I can clearly
see the hub in my window. I have the hub plugged into the back of my WiFi router via an Ethernet cable, so WiFi connection is not the problem. The connection between the timer and the hub is. Does anybody have any suggestions on how to fix this problem? If I can’t get the Pixie Z1 to have a stable connection, I will have to buy a regular Pixie.
- Nick
瀏覽: 3480   回覆: 1
Programs
Roberto Pirovano
更新時間 2024-04-06 16:31:34 UTC
瀏覽: 3298   回覆: 0
Potted Pkants
更新時間 2024-03-21 20:24:24 UTC
Wency,
Houston. Texas
瀏覽: 3616   回覆: 1
Rain delay error
David Maerzke
更新時間 2024-02-23 20:51:22 UTC
I'm getting "Error: Rain delay 1039728 with an end date of 2024-02-27."  I want to extend the delay, but it won't let me.
瀏覽: 3598   回覆: 1
Set up with mobile phone hotspot
Paul_D
更新時間 2024-02-20 07:56:42 UTC
Hi I am going to install a sprite controller at a property before wifi is installed.
Can I set up programs on the controller using hotspot from my phone? So it can then use the irrigation schedule in offline mode until I can connect to wifi.
瀏覽: 3445   回覆: 1
Connecting to Wi-Fi
Linda Lopez
更新時間 2024-02-07 16:08:44 UTC
I've had Netro for 3 years I changed my wifi and I updated it my app. It worked for a couple of weeks and all of a sudden it stopped working. I can't get it to connect to the wifi. It says offline. I can't even do a manual run. Does anyone have any suggestions?
瀏覽: 3560   回覆: 1
Istruzioni
Alexxxx
更新時間 2024-02-05 20:31:47 UTC
Dove trovo le istruzioni perla programmazione Dell app in Italiano?
瀏覽: 3421   回覆: 1
Thresholds
Shady Trails
更新時間 2023-12-23 16:16:15 UTC
瀏覽: 4210   評論: 3
Netro delivery
buggs
更新時間 2023-12-16 23:16:36 UTC
瀏覽: 3611   回覆: 1
Spark not working
Mick Faulks
更新時間 2023-11-26 07:04:12 UTC
瀏覽: 3791   回覆: 1
Scott Flanigan
更新時間 2023-11-10 17:04:48 UTC
瀏覽: 3975   回覆: 2
