Srdjan
更新時間 2023-06-11 05:21:33 UTC
瀏覽: 3709   回覆: 2
Börke Titscher
更新時間 2023-06-04 08:32:03 UTC
Folks
瀏覽: 3569   回覆: 2
D Hitch
更新時間 2023-06-03 14:10:58 UTC
Thanks for any help.
瀏覽: 3539   回覆: 1
Nero Sprite
Glenn Thurston
更新時間 2023-06-02 12:12:10 UTC
瀏覽: 3441   回覆: 1
Smart mode initial watering
Matt Ward
更新時間 2023-06-02 01:19:52 UTC
瀏覽: 3739   回覆: 1
kaitech
更新時間 2023-06-01 19:44:40 UTC
How can I troubleshoot it?
瀏覽: 3410   回覆: 1
WU PWS request pixie-Z1
Richard B
更新時間 2023-05-29 01:04:07 UTC
瀏覽: 3422   回覆: 1
Manuel Run delay
BOBBY BROWNE
更新時間 2023-05-26 00:37:50 UTC
Why is it when I hit manual run? There’s always a delay.
瀏覽: 3477   回覆: 1
A Netro Spark with no WIFI
Lino
更新時間 2023-05-25 16:07:02 UTC
Just bought a Spark and realized my home wifi sig doesn’t reach the location where it is installed.
While I sort out how to increase the signal I wonder if there is a way to program the Spark to operate without Wifi
瀏覽: 3421   回覆: 1
Netro Spark firmware version
Luis T
更新時間 2023-05-24 15:54:35 UTC
I have a Netro Spark with firmware version 3.2.1. Firmware updates are done without user intervention or how can I perform a firmware update?
瀏覽: 3788   回覆: 1
Frequently disconnection from the wifi
PaoloMassignan
更新時間 2023-05-24 05:07:48 UTC
My device is always offline unable to connect to the wifi. I have to reset it and then the connection works for a while.
There is a repeater  2 meters from it. The signal is strong.
瀏覽: 3429   回覆: 1
App Showing Ofline
Katie Wallace
更新時間 2023-05-21 11:09:21 UTC
瀏覽: 3249   回覆: 1
Nitro speak to system
Charlie Patel
更新時間 2023-05-11 18:55:33 UTC
瀏覽: 3325   回覆: 1
Anupam Kumar
更新時間 2023-05-11 00:29:18 UTC
瀏覽: 3284   回覆: 1
Home assistant integration
更新時間 2023-05-03 16:22:33 UTC
I just developed a Netro Smart Garden integration for Home Assistant.
Take a look here if interested: https://github.com/kcofoni/ha-netro-watering.
瀏覽: 5126   評論: 3
Michael Cayless
更新時間 2023-05-03 15:45:48 UTC
瀏覽: 3563   回覆: 1
Pixie Z1
Jason Willis
更新時間 2023-05-02 14:13:57 UTC
Jason Willis
Jason@wishsystems.biz
瀏覽: 3577   回覆: 1
Multiple users
Norm Markworth
更新時間 2023-04-17 00:22:59 UTC
Norm
瀏覽: 4175   回覆: 2
dummy serial for testing
更新時間 2023-04-16 17:53:00 UTC
瀏覽: 3724   回覆: 1
carlos davalos melgar
更新時間 2023-04-13 20:06:46 UTC
瀏覽: 3550   回覆: 0
