SoCal Mandatory "Once a Week" Watering
Jonathan B.
更新時間 2022-05-09 16:14:12 UTC
I've been given a notice that my county will require "Once weekly" watering beginning in June 2022. Will my Netro Sprite automatically adhere to this schedule or do I have to set it up myself?
瀏覽: 3002   回覆: 3
How do I test the sprinkler system
themaguires4727
更新時間 2022-05-08 22:44:59 UTC
The instructions on page 12 of the Netro sprite quick start guide says I can use the ‘remote control’ feature to on the Netro app to turn on and off the sprinklers. I can’t find a ‘remote control’ setting on this app.
This entire system is making me feel like an idiot. Please help.
瀏覽: 2255   回覆: 1
Unable to save programs
Arnaud
更新時間 2022-05-08 13:27:21 UTC
Hello, when I program the repeated watering schedules, it does not appear in the calendar and nothing happens.
瀏覽: 2249   回覆: 1
Activity not showing on ap
Mark Killeen
更新時間 2022-04-27 15:21:38 UTC
瀏覽: 2623   回覆: 1
Brian Brun
更新時間 2022-04-26 04:23:12 UTC
瀏覽: 2663   回覆: 1
Blinking light on my Netro
RMeador
更新時間 2022-04-21 01:20:07 UTC
瀏覽: 2223   回覆: 1
Netro lose wifi connection
Rob Rossi
更新時間 2022-04-19 09:22:12 UTC
If I restart the router,
how can it be solved?
瀏覽: 2444   回覆: 1
Alessandro Malaguti
更新時間 2022-04-18 10:04:06 UTC
I attach mp4 link
瀏覽: 2233   回覆: 1
Mike Ahlmann
更新時間 2022-04-06 18:41:13 UTC
瀏覽: 2793   回覆: 1
Maureen Horan
更新時間 2022-04-05 17:22:11 UTC
How do I add a zone
瀏覽: 2518   回覆: 1
Addind new pixie
jesusvenegas
更新時間 2022-03-29 13:10:04 UTC
瀏覽: 2259   回覆: 1
Smart Zone over watering
Scott Flanigan
更新時間 2022-03-26 11:21:58 UTC
瀏覽: 2710   回覆: 1
Werner Baier
更新時間 2022-03-26 09:58:21 UTC
瀏覽: 2608   回覆: 1
Lloyd Walter
更新時間 2022-03-23 08:31:18 UTC
瀏覽: 4619   評論: 3
更新時間 2022-03-21 21:37:50 UTC
瀏覽: 3138   回覆: 1
Whisper sensor
Anthony Bowersox
更新時間 2022-03-11 00:01:41 UTC
瀏覽: 2396   回覆: 1
Wifi issues
Anthony Bowersox
更新時間 2022-02-27 22:11:24 UTC
瀏覽: 2353   回覆: 1
Netro Spark
ELBOUHSSAINI larbi
更新時間 2022-02-25 12:22:22 UTC
瀏覽: 2424   回覆: 1
Whisper temperature and solar data availability to ITTT
August Divjak
更新時間 2022-02-11 18:31:44 UTC
Whisper temperature and solar data availability to ITTT or another application so I can trigger events on Leviton system.
瀏覽: 2606   回覆: 1
I can’t seem to be able to reschedule my program
cmeital
更新時間 2022-02-07 21:51:50 UTC
瀏覽: 2305   回覆: 1
