Marcos De Maria
更新時間 2022-02-07 19:44:16 UTC
Buenas ! No logro que prenda el riego .. si ven en la
Foto tengo una electro válvula roja .. para un lado funciona el llenado de la pileta , para el otro el riego x manguera .. en 0 Que es donde está en la foto debería darle la orden la computadora para que encienda la bomba y empiece a regar q estoy haciendo mal ??
瀏覽: 2688   回覆: 2
Jamie Campbell
更新時間 2022-01-16 22:09:35 UTC
Every time I go to login to the app, it crashes back to the iOS Home Screen. I’m running iOS 15.1.1 on an iPhone mini. I have tried deleting and reinstalling the app several times and the app works until I put my login details in, then it crashes.
瀏覽: 2740   回覆: 2
No wifi connection
lawnguy4
更新時間 2022-01-10 05:16:03 UTC
Just got the Sprite 6 controller and it won't connect to Wi-Fi. I have a mesh wi-fi system and the controller has full bars but it just refuses to connect. I reset it a couple times , I  unplugged and plugged it back in , I tried deleting the app and doing it again and still no luck. I just keep getting an error saying ''Action control parameter missing or value is empty'' no clue what that means. Can anyone give me some advice on what else I can possibly do to make this work.. Thank you.
瀏覽: 2512   回覆: 1
What is the expected format for entering weather underground? weather id?
August Divjak
更新時間 2022-01-07 23:41:01 UTC
For
KFLORLAN660 Id in weather underground app,. The setup continues to state that I should supply a valid I'd code.  I've tried many different ways with no luck.  Can you help here?
瀏覽: 2807   回覆: 1
Master valve issue.
Danny L
更新時間 2021-12-29 04:13:11 UTC
瀏覽: 3097   回覆: 1
Whisper at 0%
Darren Cassar
更新時間 2021-12-27 09:00:28 UTC
瀏覽: 2625   回覆: 1
Nguyễn Vinh
更新時間 2021-12-09 08:29:48 UTC
瀏覽: 2931   回覆: 1
Lawrence Mantin
更新時間 2021-12-05 17:01:06 UTC
瀏覽: 2623   回覆: 1
Vieri Verze
更新時間 2021-11-29 23:09:31 UTC
瀏覽: 2739   回覆: 1
Whisperer failed?
Marlpit
更新時間 2021-11-15 21:27:46 UTC
瀏覽: 3429   回覆: 2
Blowout in the rain
lugo
更新時間 2021-11-12 19:02:41 UTC
瀏覽: 2560   回覆: 1
Erros
Nabil Ben ismail
更新時間 2021-11-10 13:50:29 UTC
Erreur 4847 ? C'est quoi
瀏覽: 2540   回覆: 1
How to do a manual zone start
Jim Smith
更新時間 2021-11-07 00:41:28 UTC
瀏覽: 3048   回覆: 1
Nuova interfaccia penosa!!
Andrea DiPi
更新時間 2021-11-05 03:00:01 UTC
瀏覽: 5331   評論: 1
Home page
更新時間 2021-11-04 12:39:30 UTC
Nothing changed
瀏覽: 2960   回覆: 1
Greg Thomason
更新時間 2021-11-02 12:54:58 UTC
Hello.
瀏覽: 2776   回覆: 3
Disconnect irrigation
更新時間 2021-11-02 10:24:53 UTC
瀏覽: 2895   回覆: 0
Battery Dead
Alan Stout
更新時間 2021-10-31 16:55:02 UTC
瀏覽: 2692   回覆: 2
How to connect to Google?
Sheryl New
更新時間 2021-10-20 19:28:25 UTC
I can't connect to Google
瀏覽: 2867   回覆: 1
Smart watering
Alisa Benningfield
更新時間 2021-10-17 04:02:18 UTC
瀏覽: 2646   回覆: 1
