MEANING OF code E2
balvant patel
更新時間 2023-02-02 16:06:49
What is E2 means?
Pl. reply ASAP
Patel
瀏覽: 3197   回覆: 1
Vanina Lesko
更新時間 2023-02-03 09:47:24
瀏覽: 3296   回覆: 1
Smart schedules
Vincent Coutinho
更新時間 2023-02-07 20:51:01
瀏覽: 3364   回覆: 1
Whispered sola panel deteriorated after 6 months
更新時間 2023-02-08 06:15:54
After 6 months of whispere’s exposed to sun, the protective layer of screen is started yo be deteriorated, losing the transparency property and protection to UV, meaning is catching up less sun.
Answer from Netro support after several exchanges had not been at the right level, despite that last topic was really well addressed.
“Thanks for your info and it should not affect the normal use of the sensor. Please let us know if you see any further issues during use.
Check pictures and make your statement, but I am not convince about quality of manufacturing of the whispered elements.
David
瀏覽: 3456   回覆: 1
Set watering days
Mel Culley
更新時間 2023-02-12 02:31:35
I am struggling to set up the watering days
There isn’t an option for 4 / 3 / 4 rostered days which is are allocation here in Perth Australia
Please advise
TIA 👍
瀏覽: 5096   回覆: 2
Richard
更新時間 2023-02-17 06:29:52
Hi there.
Cheers.
瀏覽: 3447   回覆: 2
Smart zone manual setup
Vieri Verze
更新時間 2023-02-18 08:31:43
I do not understand how many millimeters to set. I have microsprinklers of 4lt/h and 2lt/h. I thought to set to 4000ml/h but the max is 100ml/h.
How to calculate? I have a big terrace with 30 plants and various microsprinklers.
Vieri
瀏覽: 3446   回覆: 2
Location Setting
ubo25
更新時間 2023-02-18 10:10:44
Please advise how I can change the location. I am staying in Windhoek, Namibia.
瀏覽: 3111   回覆: 1
Notifications/Wunderground
Fernando AT
更新時間 2023-02-26 18:00:46
Hello!
1. How can I enable notifications (when watering, sensor moisture level…)?
2. Cannot set my Wunderground station ISANTA605.
瀏覽: 3225   回覆: 1
Scheduled for March watering says next watering April
Texas AF
更新時間 2023-03-03 14:31:32
This is so damn frustrating to use.
I set to water every odd day.  Start in March.  It’s March 3rd no watering being done and the app says next watering April.
Any suggestions?   Been struggling with this app for two years now about to give up
瀏覽: 3135   回覆: 1
Shedule
jmgrau
更新時間 2023-03-09 07:21:43
How can I program the app so that it does not do automatic shedule watering, only those programmed manually, I only want the gespa dalt and gespa baix dryers to irrigate 1 minute a day.
瀏覽: 3200   回覆: 1
更新時間 2023-03-15 08:50:34
瀏覽: 3375   回覆: 1
Feature request
更新時間 2023-03-15 12:51:04
瀏覽: 3423   回覆: 2
Whisperer is suddenly crazy
JM del Amo
更新時間 2023-03-15 15:39:31
After a lot of time working fine, suddenly whisperer is crazy. With no reason suddenly the humidity is at "0" and the temperatures are above "90". I have cleaned with water the whispers. I have cleaned the device with water but remains doing same random mistake-
瀏覽: 3307   回覆: 1
Is Netro that smart?
Alessandro Alfei
更新時間 2023-03-16 00:53:44
why if Netro is so smart after months of learning with the whisperer still uses the "humidity to add watering" data set by me and doesn't create a custom program?  smartzone is in advanced level and regular mode.
瀏覽: 3465   回覆: 2
Carlo Drago
更新時間 2023-03-18 18:55:41
Waiting your kind reply
Carlo
瀏覽: 3370   回覆: 1
cannot connect my pixie to mi wifi with unifi Access point
christophe Minery
更新時間 2023-03-24 18:42:53
Someone can help me to connect to my unifi Wifi tm sensor Pixie ?
All goes OK unitl last step.... when it tell me that I connect connect to it
thanks
瀏覽: 3825   回覆: 1
Dont't start manual irrigation
Simone Teressi
更新時間 2023-03-26 11:39:57
I've checked that My netro isonline...but if i start a manual irrogation app say to me "communicating" and never begin to start..... If i turn off elecrticity and turn on again..... And then i go to manual  Irrogation and press start irrogation begin immediatly
瀏覽: 3219   回覆: 1
No 24V output?
Bigolin Davide
更新時間 2023-03-26 16:15:24
What can I do?
瀏覽: 3118   回覆: 1
No wifi connection
gdimofte@gmail.com
更新時間 2023-03-27 18:00:53
Dear Sir
Gabriel
瀏覽: 3072   回覆: 1
