Suggestions and Question.
Maurizio Gianesin
更新時間 2023-04-12 15:08:32 UTC
Good morning.
I just started using Netro Sprite 8 zones out of 12 zones with two whisperers.
Congratulations for the App and the Web interface I'm using.
I have a concern about some trivial errors in the interfaces:
If you go to settings/preferences/SchedulingSetting
1.1 The Italian translation of "Two Frames" in "Due Cornici" makes me smile, it is better translated in "Due Cicli" or "Due Fasi". But my suggestion is also for English : it is my opinion that if instead of "Time Frames" and "Two Frames" you use "Time Phase" and "Two Phase" it is much better also for English and automatic translations free from misunderstandings.
1.2 Only in the App and not on the Web, the description of the two phases has "afternoon" under "morning" and vice versa.
Now I have a question:
I ask you for an explanation on Smart Scheduling.
I had set a lower limit of 10 C° and a Time Phase of 6:00 - 10:00. When I removed the 10 C° limit, the system did the same day a cycle at 23:58 instead of waiting for 6:00. why?
I hope I have been helpful and thank you for any response.
瀏覽: 3339   回覆: 1
Wasteful
David Maerzke
更新時間 2023-04-13 13:19:47 UTC
瀏覽: 3358   回覆: 1
carlos davalos melgar
更新時間 2023-04-13 20:06:46 UTC
瀏覽: 3377   回覆: 0
更新時間 2023-04-13 20:06:57 UTC
瀏覽: 4098   回覆: 0
更新時間 2023-04-13 20:07:05 UTC
瀏覽: 4057   回覆: 1
Matt Ward
更新時間 2023-04-14 13:57:11 UTC
Matt
瀏覽: 3505   回覆: 3
Intelligent mode useless
Juan Lambea
更新時間 2023-04-14 15:51:37 UTC
瀏覽: 4363   回覆: 1
dummy serial for testing
更新時間 2023-04-16 17:53:00 UTC
瀏覽: 3572   回覆: 1
Multiple users
Norm Markworth
更新時間 2023-04-17 00:22:59 UTC
Norm
瀏覽: 4007   回覆: 2
Pixie keeps disconnecting
Sang Peiris
更新時間 2023-04-18 12:44:42 UTC
瀏覽: 3433   回覆: 1
Add user Error
更新時間 2023-04-21 09:26:43 UTC
瀏覽: 3193   回覆: 2
farenheit to celsius
Santiago Moller
更新時間 2023-04-22 02:41:55 UTC
Hello, I need help to change the settings from Fahrenheit to Celsius in the app, I have a smart plant sensor.  Thank you
瀏覽: 3908   回覆: 1
Area
Javier Domínguez
更新時間 2023-04-22 16:04:10 UTC
Hola,
Cuando estoy configurando las zonas me pide un valor de area, ¿en qué medida? ¿Metros cuadrados?
瀏覽: 3435   回覆: 1
valves under relay
Alek
更新時間 2023-04-22 17:48:29 UTC
瀏覽: 4289   回覆: 1
Master error “open circuit”
Neil Lucey
更新時間 2023-04-24 14:09:12 UTC
Neil
瀏覽: 3320   回覆: 1
更新時間 2023-04-24 14:27:08 UTC
Sprite / app
Never before
Disconnection to wifi
Even when say : online
irrigation )
瀏覽: 3674   回覆: 1
Jim
更新時間 2023-04-24 17:38:25 UTC
瀏覽: 3534   回覆: 2
Katie Woggins
更新時間 2023-04-24 18:40:07 UTC
瀏覽: 3287   回覆: 1
0 Minute Zones?
Stephen Wyatt
更新時間 2023-04-26 12:59:02 UTC
瀏覽: 3116   回覆: 1
How to cancel schedule
Wayne Curdy
更新時間 2023-04-27 01:15:38 UTC
瀏覽: 3149   回覆: 1
