Ananth
更新時間 2022-09-21 12:25:49 UTC
 How do i change this?
lot of water being wasted.
Ananth Bandla
瀏覽: 4417   回覆: 2
Sprite-6
Rockhead413
更新時間 2022-09-26 18:04:30 UTC
Vincent Devlahovich
瀏覽: 3802   回覆: 1
Irrigation program,
Rosario Russo
更新時間 2022-09-27 10:58:58 UTC
Rosario
瀏覽: 3729   回覆: 1
Rosario Russo
更新時間 2022-09-27 11:06:57 UTC
瀏覽: 3749   回覆: 1
Rick Miller
更新時間 2022-09-29 23:49:53 UTC
瀏覽: 3803   回覆: 1
Veronica Slaughter
更新時間 2022-10-01 05:11:02 UTC
Any insight is so welcome!
瀏覽: 3734   回覆: 1
Discover and weather accuracy
Geron R
更新時間 2022-10-01 12:38:37 UTC
瀏覽: 3839   回覆: 1
No connection to WiFi.
Gianluca De Virgilio
更新時間 2022-10-02 21:48:54 UTC
Good afternoon.
瀏覽: 4354   回覆: 2
Main feeder line shutoff valve control
Richard Miles
更新時間 2022-10-10 02:16:36 UTC
My main water line to the sprinkler system came loose and flooded my vacation home yard with 250,000 gallons of water before the leak was discovered and repaired.  Does Netro have the ability to control an electric valve on this feeder line such that the main valve will only open when the irrigation system calls for water?
瀏覽: 3762   回覆: 1
Weather station
更新時間 2022-10-14 02:07:16 UTC
瀏覽: 4086   回覆: 1
Water pressure
Omer Zadikevitch
更新時間 2022-10-18 18:15:38 UTC
瀏覽: 3672   回覆: 1
更新時間 2022-10-20 14:57:19 UTC
Thanks for your advice
瀏覽: 3731   回覆: 1
Water valve opened
Paolo Talamelli
更新時間 2022-10-23 10:52:29 UTC
瀏覽: 3499   回覆: 1
Cutrone
更新時間 2022-10-25 17:06:24 UTC
Hello all!
瀏覽: 4150   回覆: 2
Daniel Gajardo
更新時間 2022-10-27 01:22:57 UTC
瀏覽: 3775   回覆: 1
Percentage Adjustment
jeremyagrelius@gmail.com
更新時間 2022-10-29 18:31:12 UTC
瀏覽: 3629   回覆: 1
LearNetro Whisperer
更新時間 2022-10-30 19:15:38 UTC
At the end of the whisperer's learning time, the times are set automatically in the program or have to be done manually?
瀏覽: 4070   回覆: 2
Gianluca Bus
更新時間 2022-11-03 12:03:59 UTC
Hi all!
Netro App vesion: 3.1.0
Netro controller hw ver.: 1.2
Thanks in advance.
Gianluca
瀏覽: 3588   回覆: 1
Carlo Drago
更新時間 2022-11-04 18:48:50 UTC
Carlo
瀏覽: 3664   回覆: 1
Netro light
Alessandro Zannini
更新時間 2022-11-05 20:16:40 UTC
瀏覽: 3395   回覆: 1
