更新時間 2023-03-15 08:50:34 UTC
瀏覽: 3556   回覆: 1
Feature request
更新時間 2023-03-15 12:51:04 UTC
瀏覽: 3597   回覆: 2
Whisperer is suddenly crazy
JM del Amo
更新時間 2023-03-15 15:39:31 UTC
After a lot of time working fine, suddenly whisperer is crazy. With no reason suddenly the humidity is at "0" and the temperatures are above "90". I have cleaned with water the whispers. I have cleaned the device with water but remains doing same random mistake-
瀏覽: 3480   回覆: 1
Is Netro that smart?
Alessandro Alfei
更新時間 2023-03-16 00:53:44 UTC
why if Netro is so smart after months of learning with the whisperer still uses the "humidity to add watering" data set by me and doesn't create a custom program?  smartzone is in advanced level and regular mode.
瀏覽: 3659   回覆: 2
Carlo Drago
更新時間 2023-03-18 18:55:41 UTC
Waiting your kind reply
Carlo
瀏覽: 3550   回覆: 1
cannot connect my pixie to mi wifi with unifi Access point
christophe Minery
更新時間 2023-03-24 18:42:53 UTC
Someone can help me to connect to my unifi Wifi tm sensor Pixie ?
All goes OK unitl last step.... when it tell me that I connect connect to it
thanks
瀏覽: 4034   回覆: 1
Dont't start manual irrigation
Simone Teressi
更新時間 2023-03-26 11:39:57 UTC
I've checked that My netro isonline...but if i start a manual irrogation app say to me "communicating" and never begin to start..... If i turn off elecrticity and turn on again..... And then i go to manual  Irrogation and press start irrogation begin immediatly
瀏覽: 3391   回覆: 1
No 24V output?
Bigolin Davide
更新時間 2023-03-26 16:15:24 UTC
What can I do?
瀏覽: 3285   回覆: 1
No wifi connection
gdimofte@gmail.com
更新時間 2023-03-27 18:00:53 UTC
Dear Sir
Gabriel
瀏覽: 3248   回覆: 1
Sprinklers not going off per schedule
Brian Brun
更新時間 2023-03-28 22:50:06 UTC
What are my sprinklers not going off per schedule? I have a schedule that it supposed to kick off Tuesday and Thursday. It is set to start at 6:00. It is 6:50 and it has not went off. I just had to manually run a cycle.
瀏覽: 3521   回覆: 1
Vincent Pollinzi
更新時間 2023-03-30 22:43:53 UTC
瀏覽: 3266   回覆: 1
Michael Cayless
更新時間 2023-04-02 21:21:01 UTC
瀏覽: 3513   回覆: 1
Phone number
Graham Corrett
更新時間 2023-04-05 13:07:22 UTC
Does anyone I have a contact/help number for this company possibly in the UK I’ve sent an email but no response!
瀏覽: 3396   回覆: 1
Netro Sprite + Netro Pixie Z1
xergyo
更新時間 2023-04-10 09:58:51 UTC
Is it possible to connect the Netro Pixie Z1 to the wifi and to the App using the Netro Sprite without the need for the Netro Hub?
瀏覽: 4138   回覆: 1
Pixie linked to 2 iphone
Paolo S
更新時間 2023-04-10 13:29:30 UTC
Is it possible to control 1pixie with 2 iphone?
瀏覽: 3348   回覆: 1
更新時間 2023-04-10 15:17:46 UTC
Hi there
- seed type
- watering adjustement - EPA
- how tall to cut the grass
瀏覽: 3652   回覆: 1
Abraio
更新時間 2023-04-10 17:53:48 UTC
瀏覽: 3235   回覆: 1
Wiring multiple controllers
John Wright
更新時間 2023-04-10 19:05:31 UTC
I have an existing 18 zones irrigation controller which I am replacing. I require 2 controllers. No master valve or pump.
It is possible to connect both commons to the existing common connected to the 18 zones?
瀏覽: 4256   回覆: 1
Maximum watering duration for SPARK
Katarzyna Wrobel
更新時間 2023-04-11 22:55:50 UTC
Hi there :)
I want to set-up a watering duration for my desert garden (Phoenix, AZ). We should water our garden deeply and infrequently. So, I want to set-up a watering time of two hours. Unfortunately, the app has a maximum duration set to 60 minutes only. Any suggestions?
瀏覽: 3247   回覆: 1
Whisper will not factory reset!
Ross Brown
更新時間 2023-04-13 10:43:03 UTC
Hi I have had to send back my spark due to a problem with one zone not operating, I’m now trying to do a reset on my whisper, I have pressed the power button quickly 6 times, on numerous occasions and cannot get it to reset, any help would be much appreciated. New Spark arrived and working well, l just can’t seem to reset the Whisper no matter how many times I try the on/off 3 times. Are there any other action I could do or do I return it for a replacement?
瀏覽: 4191   回覆: 1
