Scott Gustafson
更新時間 2022-04-14 22:26:18 UTC
瀏覽: 3942   回覆: 1
idpitt
更新時間 2022-04-16 13:50:17 UTC
What am I missing?
瀏覽: 3744   回覆: 1
Watering days
更新時間 2022-04-16 18:22:19 UTC
Home display is correct and shows Last watering the day before at the date and time in the program (watering planned everyday) but under Discover many days are shown as if there has not been any irrigation.
What could be the reason why ?
瀏覽: 4011   回覆: 2
Feature Request
Tod Johnson
更新時間 2022-04-16 18:22:20 UTC
瀏覽: 3315   回覆: 1
Gaspare Miceli
更新時間 2022-04-18 06:23:55 UTC
瀏覽: 4766   回覆: 1
Alessandro Malaguti
更新時間 2022-04-18 10:04:06 UTC
I attach mp4 link
瀏覽: 3220   回覆: 1
Wifi connection
更新時間 2022-04-18 11:31:15 UTC
瀏覽: 3615   回覆: 1
Netro lose wifi connection
Rob Rossi
更新時間 2022-04-19 09:22:12 UTC
If I restart the router,
how can it be solved?
瀏覽: 3435   回覆: 1
John Lillistone
更新時間 2022-04-19 11:26:49 UTC
瀏覽: 3442   回覆: 1
Davide M.
更新時間 2022-04-20 09:23:18 UTC
Good day all,
Thanks for help.
Davide
瀏覽: 3673   回覆: 1
ITA Translation
Davide M.
更新時間 2022-04-20 07:21:19 UTC
Hi all,
Best Regards,
Davide
瀏覽: 3575   回覆: 1
Blinking light on my Netro
RMeador
更新時間 2022-04-21 01:20:07 UTC
瀏覽: 3191   回覆: 1
doppia irrigazione
mauro croce
更新時間 2022-04-22 10:52:27 UTC
瀏覽: 3728   回覆: 1
Whisper Sensor
Ian Moore
更新時間 2022-04-26 02:55:10 UTC
瀏覽: 3710   回覆: 1
Brian Brun
更新時間 2022-04-26 04:23:12 UTC
瀏覽: 3661   回覆: 1
Calendar won’t update
Yuanchao X
更新時間 2022-04-26 19:44:49 UTC
瀏覽: 3342   回覆: 2
J H
更新時間 2022-04-26 20:17:38 UTC
瀏覽: 3503   回覆: 1
Activity not showing on ap
Mark Killeen
更新時間 2022-04-27 15:21:38 UTC
瀏覽: 3629   回覆: 1
Netro Whisperer
Fabrice GOUFFRAN
更新時間 2022-04-28 12:29:53 UTC
I am unable to have my new whisperer working. It doesn’t light on even after half a day under the sun.
瀏覽: 4217   回覆: 1
Incorrect rainfall accumulation
rwflower
更新時間 2022-04-29 16:35:33 UTC
I live in Katy Texas and have been using the Netro water controller in smart mode for over 2 years with no problems.  We received at least 1.5in of rain on the April 25, so I was dismayed to find my sprinkler system watering my yard on the morning of the 26th.  The rain graph in the app is showing 0.03in for the 25th and is clearly wrong.  I have tried changing to all the different weather providers, but the total rain accumulation doesn't change.  The frontal system that caused the rain passed over the entire area, so this is not a situation of local shower only affecting a localized area.
瀏覽: 3918   回覆: 2
