Netro Sprite 6 no enciende la bomba
Vanina Lesko
更新時間 2022-02-20 12:24:48 UTC
Hicimos la instalación tal como figura el manual pero ni las electroválvulas ni la bomba de agua enciende cuando programó el riego. La app dice q está regando pero no funciona el riego.
瀏覽: 4527   回覆: 2
future user of your device
ELBOUHSSAINI larbi
更新時間 2022-02-24 22:49:40 UTC
currently I have a rain bird 4 station device without wifi which gives me satisfaction but unfortunately without wifi zpres research on the internet your device interests me and I want to have some explanation
 - does the device work and trigger the irrigation program in case of wifi failure
 -Does the device back up program data in the event of a power outage?
 - does the humidity sensor come with the device i no where can i buy it
 thank you for answering my questions
瀏覽: 3547   回覆: 1
Netro Spark
ELBOUHSSAINI larbi
更新時間 2022-02-25 12:22:22 UTC
瀏覽: 3381   回覆: 1
Meteo
Rob Rossi
更新時間 2022-02-25 13:46:37 UTC
How can i solve?
Thanks very much
瀏覽: 3491   回覆: 2
Wifi issues
Anthony Bowersox
更新時間 2022-02-27 22:11:24 UTC
瀏覽: 3315   回覆: 1
Interface
John Degolyer
更新時間 2022-03-02 05:58:45 UTC
瀏覽: 4130   回覆: 2
Gabriele Cofano
更新時間 2022-03-02 12:45:59 UTC
瀏覽: 3650   回覆: 1
Whisper sensor
Anthony Bowersox
更新時間 2022-03-11 00:01:41 UTC
瀏覽: 3335   回覆: 1
Netro pixie in standby
mbhi
更新時間 2022-03-12 10:44:15 UTC
瀏覽: 3643   回覆: 1
Problem Sprite 6
Davide Benfenati
更新時間 2022-03-12 16:41:44 UTC
瀏覽: 3585   回覆: 1
It says it sleeping
Judith Soth
更新時間 2022-03-12 22:25:49 UTC
瀏覽: 3454   回覆: 1
Flow rate
Sander Z
更新時間 2022-03-14 12:34:05 UTC
瀏覽: 3604   回覆: 1
Justin Kirk
更新時間 2022-03-16 14:24:09 UTC
瀏覽: 3462   回覆: 2
Whisperers not sending data
更新時間 2022-03-18 12:17:29 UTC
瀏覽: 3882   回覆: 1
Mark Killeen
更新時間 2022-03-18 21:39:54 UTC
瀏覽: 3684   回覆: 1
Joe Baxter
更新時間 2022-03-18 22:42:37 UTC
瀏覽: 3696   回覆: 3
Hitesh
更新時間 2022-03-20 00:34:11 UTC
瀏覽: 3740   回覆: 2
Lost connection
Simone Teressi
更新時間 2022-03-20 16:49:15 UTC
Router signal is 100%
瀏覽: 3610   回覆: 1
John Gerst
更新時間 2022-03-21 14:10:28 UTC
瀏覽: 3439   回覆: 1
metellusa@gmail.com
更新時間 2022-03-21 18:45:44 UTC
瀏覽: 3873   回覆: 1
