Location outside USA
Eduardo Prieto
更新時間 2022-04-30 09:45:16 UTC
I live in Spain and ubication selector do not let me specify my correcto location. I assume It is requieres to provide the Meteorological service the place where to predict weather, so if location is incorrect, the weather too and the watering planning is not optimized properly.
Please work It out un Next app releases.
瀏覽: 3541   回覆: 1
Dhar Sawh
更新時間 2022-05-01 13:26:09 UTC
Dhar
瀏覽: 3663   回覆: 2
Pixie shows "communicating" and timer counting down but valve not open?
Douglas Ely
更新時間 2022-05-01 15:54:22 UTC
When trying to use the Pixie to manually water the garden, I go to the Netro app and select the pixie. It shows "sleeping", 99%charged. I then select "manual run" and set a time. The app then grays out and says "communicating" as the timer begins counting down my preset manual time but the valve stays closed. Why? When does it open?
瀏覽: 4314   回覆: 3
Wifi reconnect issue
Giacomo
更新時間 2022-05-03 21:04:03 UTC
Hi All,
I'm a satisfied Italian customer of Netro Sprite 12 zones since 2019!
Recently I set my router to shutdown the wifi during the night, the Netro sprite it's the only one device that don't automatically reconnect when wifi come up in the morning, the white LED still blinking. To reconnect at the network, I need to phisically shutdown and power on the Sprite.
Is there a "trick" or an update to cover this issue? HW Version: 1.2 , Firmware Version 1.1.3
Thanks in advance.
Giacomo
瀏覽: 4935   回覆: 5
Rain stop
Javier Baruque
更新時間 2022-05-03 14:52:20 UTC
瀏覽: 3424   回覆: 1
water valve does not work
Paolo Raviolo
更新時間 2022-05-03 15:55:47 UTC
I set up the pixie timer, everithing seems ok but the valve does not opens, nor with program nor in manual mode, no water at all.
can you help me?
瀏覽: 3613   回覆: 1
No moisture reading
dsingelyn
更新時間 2022-05-04 17:59:14 UTC
Suggestions?
瀏覽: 3839   回覆: 3
Smart watering -how do I know
John Kot
更新時間 2022-05-05 21:44:57 UTC
If I have smart watering enabled does it activate sprinklers when it (sprite) determines a need?  If so how do I prevent that when I happen to be mowing the lawn?
瀏覽: 3851   回覆: 1
mspenner3
更新時間 2022-05-06 00:09:34 UTC
瀏覽: 3384   回覆: 1
Unable to save programs
Arnaud
更新時間 2022-05-08 13:27:21 UTC
Hello, when I program the repeated watering schedules, it does not appear in the calendar and nothing happens.
瀏覽: 3213   回覆: 1
How do I test the sprinkler system
themaguires4727
更新時間 2022-05-08 22:44:59 UTC
The instructions on page 12 of the Netro sprite quick start guide says I can use the ‘remote control’ feature to on the Netro app to turn on and off the sprinklers. I can’t find a ‘remote control’ setting on this app.
This entire system is making me feel like an idiot. Please help.
瀏覽: 3215   回覆: 1
Jonas Lindholm
更新時間 2022-05-09 02:22:56 UTC
瀏覽: 3318   回覆: 1
Watering out of schedule time
Luca Cerini
更新時間 2022-05-09 09:14:09 UTC
Luca
瀏覽: 3383   回覆: 1
Rain Strategy
Luca Cerini
更新時間 2022-05-09 09:24:20 UTC
Luca
瀏覽: 3408   回覆: 1
SoCal Mandatory "Once a Week" Watering
Jonathan B.
更新時間 2022-05-09 16:14:12 UTC
I've been given a notice that my county will require "Once weekly" watering beginning in June 2022. Will my Netro Sprite automatically adhere to this schedule or do I have to set it up myself?
瀏覽: 4053   回覆: 3
Broken part
Jeremie Coderre
更新時間 2022-05-10 02:52:42 UTC
Hi there!
Thanks in advance!
瀏覽: 3517   回覆: 1
Rain Delay Setting
Nicholas Lydakis
更新時間 2022-05-10 17:37:16 UTC
瀏覽: 3858   回覆: 1
pollomito
更新時間 2022-05-10 19:31:57 UTC
Netro spark can be configured and used as timer if no wifi access point are available?
It is possible to use it by connecting directly mobile phone with spark without additional devices?
Thx
瀏覽: 4154   回覆: 2
instruction manual of the Netro Sprinkler
Rolando Silvano
更新時間 2022-05-11 18:59:03 UTC
Where can I find the instruction manual of the Netro Sprinkler Smart Controller?
thank you
Silvano
瀏覽: 3681   回覆: 1
Interface language
Bayoule Bayoule
更新時間 2022-05-11 19:31:03 UTC
Bayoule
瀏覽: 3376   回覆: 1
