Smart Zone Scheduling Problem
Jon Storch
更新時間 2022-05-20 22:11:43 UTC
Hello.  After turning on my sprinkler system back on for the summer this year the Netro has not worked correctly when in Smart Zone mode.
The scheduler will add a dozen of "mini" watering tasks where the next tasks starts immediately after the current one ends. (See picture)
I have tried resetting the system.  I currently need to have the Netro system disabled and run manual tasks to water my lawn.  What can I do to have my zones in Smart Zone mode and not have this problem?
瀏覽: 3991   回覆: 1
John Rowe
更新時間 2022-05-21 00:45:45 UTC
瀏覽: 4692   回覆: 4
Battery in Pixie Reads 282%
David Halpern
更新時間 2022-05-21 13:50:23 UTC
瀏覽: 3967   回覆: 2
更新時間 2022-05-21 17:31:03 UTC
瀏覽: 3937   回覆: 1
malfunction
Ramón Sellés
更新時間 2022-05-22 10:28:57 UTC
volume_up
content_copy
share
瀏覽: 3550   回覆: 1
MQTT port is blocked
Jose Juan Dios
更新時間 2022-05-22 11:51:44 UTC
Can you help me please?
Thankyou
瀏覽: 3745   回覆: 1
更新時間 2022-05-23 14:33:07 UTC
瀏覽: 4705   回覆: 1
Meteo app
Enrico Marion
更新時間 2022-05-23 17:03:37 UTC
瀏覽: 3572   回覆: 1
Night watering
John Kot
更新時間 2022-05-23 21:15:34 UTC
瀏覽: 3832   回覆: 1
Bayoule Bayoule
更新時間 2022-05-24 18:50:51 UTC
JM
瀏覽: 3551   回覆: 2
Wayne Smith
更新時間 2022-05-24 20:51:31 UTC
瀏覽: 3566   回覆: 1
Pixie wifi connection
Luis Borrás
更新時間 2022-05-25 05:58:44 UTC
Luis
瀏覽: 3401   回覆: 1
Discover irrigation
更新時間 2022-05-25 06:52:34 UTC
瀏覽: 3723   回覆: 1
milanese
更新時間 2022-05-27 02:32:57 UTC
iPhone -
- Get app
- Crete account
- Go to connect timer
- Next
- Enter name and stuff, next
- Turn on unit, next
Please advise.
瀏覽: 3535   回覆: 1
Connection issues
Ant Va
更新時間 2022-05-27 09:57:09 UTC
瀏覽: 3959   回覆: 3
Netro screwed up
Jack Davis
更新時間 2022-05-28 16:14:25 UTC
瀏覽: 3817   回覆: 1
Schedule is empty?
Jacopo De Simoi
更新時間 2022-05-29 02:44:51 UTC
Best
 Jacopo
瀏覽: 3654   回覆: 1
Val Smith
更新時間 2022-06-30 23:53:11 UTC
瀏覽: 3736   回覆: 2
Val Smith
更新時間 2022-06-30 23:52:31 UTC
瀏覽: 3877   回覆: 1
Schedule screen
Dick Milde
更新時間 2022-05-30 14:02:03 UTC
瀏覽: 3417   回覆: 1
