Login Error: Can't find user
Patbouvry
更新時間 2022-07-04 01:08:57 UTC
Pat.
瀏覽: 3293   回覆: 1
eater flow meter
Corneliu PINTILIE
更新時間 2022-07-05 14:11:11 UTC
瀏覽: 3358   回覆: 1
Home51
更新時間 2022-07-05 20:23:39 UTC
Zev
瀏覽: 3391   回覆: 1
Laks
更新時間 2022-07-06 13:33:47 UTC
thank you
瀏覽: 3447   回覆: 1
Manual runs overriding schedule
unislock
更新時間 2022-07-07 12:02:15 UTC
Is there a way to not have manual runs conflict with the smart schedule?  At times I turn sprinklers on for kids to have fun or to test a newly installed head for a few minutes. These manual runs (even for a minute or two) in these zones are not being run during the next scheduled run. This is frustrating and now I need to do a lot of manual runs to ensure lawn gets appropriate amount of water and is basically taking away my ability to auto schedule.
Thoughts?
瀏覽: 4014   回覆: 2
Smart watering settings
SK Breuer
更新時間 2022-07-07 17:34:52 UTC
瀏覽: 3443   回覆: 1
Zones cut out
tbbucans
更新時間 2022-07-08 00:44:31 UTC
瀏覽: 3350   回覆: 1
Frank Fang
更新時間 2022-07-08 18:44:28 UTC
瀏覽: 3355   回覆: 1
WU weather provider question
Weston Hull
更新時間 2022-07-09 01:43:02 UTC
瀏覽: 3483   回覆: 1
Want to use two controllers
dl74pw@yahoo.com
更新時間 2022-07-09 14:19:31 UTC
瀏覽: 3343   回覆: 1
Power device heat
David Domingues
更新時間 2022-07-09 17:15:45 UTC
Hello all,
I just bought a Netro controller with only 2 areas setup and I like it so far.
I was wondering if the noise and heat from the power supply was a  normal thing to happen.
Thanks in advance.
瀏覽: 4299   回覆: 2
更新時間 2022-07-10 11:25:02 UTC
瀏覽: 3710   回覆: 1
Day view
更新時間 2022-07-12 04:10:37 UTC
瀏覽: 3586   回覆: 1
Netro connection to IFTTT
Sarah Kottke
更新時間 2022-07-12 13:44:09 UTC
Anyone had luck?
Sarah
瀏覽: 3642   回覆: 1
More data
Jim Shaffer
更新時間 2022-07-13 13:06:30 UTC
瀏覽: 3682   回覆: 1
Plant sensor
Miro D
更新時間 2022-07-14 10:42:35 UTC
瀏覽: 3670   回覆: 1
Waters excessively
Cindy Luvender
更新時間 2022-07-14 16:38:38 UTC
瀏覽: 3855   回覆: 1
Pixie water pressure
Chris
更新時間 2022-07-15 09:03:05 UTC
瀏覽: 3585   回覆: 1
更新時間 2022-07-15 12:27:12 UTC
瀏覽: 4202   回覆: 2
更新時間 2022-07-15 13:56:02 UTC
瀏覽: 3865   回覆: 2
