changelives
更新時間 2021-11-13 23:40:38 UTC
Did I set it up incorrectly?
瀏覽: 3878   回覆: 1
Rony
Rony Z
更新時間 2021-11-14 12:34:03 UTC
Do you have a phone number I can call you and talk to an agent?
瀏覽: 3875   回覆: 1
Whisperer failed?
Marlpit
更新時間 2021-11-15 21:27:46 UTC
瀏覽: 4635   回覆: 2
Roger Prunonosa Duran
更新時間 2021-11-22 10:30:32 UTC
They haven’t lasted much…
瀏覽: 4451   回覆: 2
Whisperer temperature and moisture readings are way off
Andrew
更新時間 2021-11-28 00:35:49 UTC
I recently bought a whisperer and for the first few days it worked perfectly but now it consistently reports the temperature as being over 300 degrees celcius, and soil moisture at 0% even while it has been raining here for a week.
I've tried relocating the whisperer and deleting and re-setting it up twice but get the same result.
I'm unsure what else to try. Does anyone have advice or a fix for issues like this?
瀏覽: 4555   回覆: 2
Vieri Verze
更新時間 2021-11-29 23:09:31 UTC
瀏覽: 3714   回覆: 1
I have problem with netro pixie
Nguyễn Vinh
更新時間 2021-12-01 06:33:51 UTC
My Pixie can't enable manual mode, when i manually launch the app it says "Pending" and it doesn't work
瀏覽: 3839   回覆: 1
arubalsky
更新時間 2021-12-01 13:44:22 UTC
Example:
Pixie 1 - Nov 24 - Good run
Pixie 2 - Nov 24 - Good run
Pixie 2 - Nov 26 - Good run
Pixie 1 - Nov 28 - Good run
Pixie 2 - Nov 28 - Good run
Pixie 2 - Nov 30 - Good run
瀏覽: 3825   回覆: 1
Lawrence Mantin
更新時間 2021-12-05 17:01:06 UTC
瀏覽: 3567   回覆: 1
Nguyễn Vinh
更新時間 2021-12-09 08:29:48 UTC
瀏覽: 3912   回覆: 1
Login Error
alexepn
更新時間 2021-12-10 19:26:10 UTC
瀏覽: 3542   回覆: 1
Titousensei
更新時間 2021-12-12 22:51:43 UTC
瀏覽: 4394   回覆: 4
Zone danssqm ?
SCAN Tektal
更新時間 2021-12-13 18:42:06 UTC
瀏覽: 4046   回覆: 3
davejburton@gmail.com
更新時間 2021-12-16 01:35:31 UTC
Howdy!
瀏覽: 3721   回覆: 1
Lyndon Whyatt
更新時間 2021-12-22 19:53:57 UTC
I reset my Whisperer sensor by following the reset instructions and on restart it flashed white. I added the sensor via the app but it didn’t produce a WiFi signal and I couldn’t connect to it in Settings on my iPhone. After a while it flashes dark blue.
What is happening and how can I fix it?
瀏覽: 4018   回覆: 1
Manual recurring programs
Mark Johnston
更新時間 2021-12-23 23:56:32 UTC
Merry Xmas everyone
瀏覽: 3661   回覆: 1
2 programs scheduled on one day
paul hewitt
更新時間 2021-12-24 05:21:45 UTC
I added an afternoon program after the morning one had run to run daily as very hot over next few days. After setting it up I went into schedule to make sure it was there and all that appears on the day is the morning schedule with a yellow triangle with exclamation mark instead of the usual tick to say it was done. I did see it running the morning schedule.
Why doesn't the afternoon schedule show up as well as the morning one?
Paul
瀏覽: 3847   回覆: 1
Whisper at 0%
Darren Cassar
更新時間 2021-12-27 09:00:28 UTC
瀏覽: 3598   回覆: 1
Master valve issue.
Danny L
更新時間 2021-12-29 04:13:11 UTC
瀏覽: 4110   回覆: 1
Jamie Campbell
更新時間 2021-12-29 10:45:55 UTC
Can you help?
瀏覽: 3578   回覆: 2
