更新時間 2021-08-22 13:48:00 UTC
瀏覽: 4009   回覆: 1
Adjusting Rain Fall
Mike Jones
更新時間 2021-08-24 09:19:23 UTC
Hi guys an girls.
Miky
瀏覽: 3853   回覆: 2
更新時間 2021-08-26 14:17:28 UTC
瀏覽: 3969   回覆: 2
Delete all schedules
Sharwell
更新時間 2021-08-27 14:41:04 UTC
I have added too many schedules on top of smart watering. How can I delete and start all over?
瀏覽: 4249   回覆: 3
Whisperer not working right.
vkanaga
更新時間 2021-08-27 23:46:35 UTC
瀏覽: 3992   回覆: 1
Manual watering stops before end of schedule
Patrice Kestenberg
更新時間 2021-08-29 16:13:57 UTC
I’ve got a sprite 6 system with 3 zones configured and no master valve
The watering stops before the end of planned schedule.
So I’ve deactivated all smart function to check, manual launch planned for 5 minutes.
It starts and after 15seconds it stops watering.
Any idea why?
瀏覽: 4458   回覆: 1
Jean-François FOULT
更新時間 2021-08-29 17:46:56 UTC
Thanks for help
J Francois
瀏覽: 3544   回覆: 1
更新時間 2021-08-31 09:42:59 UTC
DEEP
EPA
REGULAR
FREQUENT
Any advice?
瀏覽: 4256   回覆: 1
Sean Eatch
更新時間 2021-09-01 01:08:02 UTC
瀏覽: 3964   回覆: 1
更新時間 2021-09-07 09:58:44 UTC
瀏覽: 4169   回覆: 1
carloswhisperer
更新時間 2021-09-07 22:45:21 UTC
瀏覽: 3691   回覆: 1
Program Not Running
Wally Carnes
更新時間 2021-09-09 02:37:52 UTC
瀏覽: 4242   回覆: 2
Jacques
更新時間 2021-09-09 15:28:26 UTC
瀏覽: 3925   回覆: 1
No data registers as zero
Dave C
更新時間 2021-09-10 22:06:38 UTC
瀏覽: 3484   回覆: 1
Connexio
Gerard Coulombe
更新時間 2021-09-12 11:02:25 UTC
Help needed
瀏覽: 3649   回覆: 1
Power Supply
Jason Willis
更新時間 2021-09-12 12:27:04 UTC
Jason Willis
瀏覽: 4104   回覆: 1
Can't get our Netro to reset
Neil Hobbs
更新時間 2021-09-13 20:54:12 UTC
瀏覽: 3797   回覆: 1
Moisture sensors not working
Nancy Lamm
更新時間 2021-09-15 14:13:04 UTC
瀏覽: 3879   回覆: 1
new xfinity box
gary graham
更新時間 2021-09-16 04:04:06 UTC
瀏覽: 3614   回覆: 1
BOB COOPER
更新時間 2021-09-16 17:05:56 UTC
瀏覽: 3913   回覆: 1
