Internet down
更新時間 2021-07-18 11:38:25 UTC
瀏覽: 4086   回覆: 2
Addiel Isaac Moldes
更新時間 2021-07-18 12:42:37 UTC
It was or wasn't included?
瀏覽: 3979   回覆: 1
Default view on startup
Addiel Isaac Moldes
更新時間 2021-07-18 12:45:53 UTC
瀏覽: 3826   回覆: 1
wwhitfill
更新時間 2021-07-18 13:52:07 UTC
瀏覽: 3878   回覆: 2
Barry Litinsky
更新時間 2021-07-18 23:12:56 UTC
瀏覽: 3622   回覆: 1
Pixie and Whisperer
Nick Thoman
更新時間 2021-07-19 17:46:37 UTC
瀏覽: 3976   回覆: 1
Ramón Rivero
更新時間 2021-07-20 08:32:53 UTC
瀏覽: 3753   回覆: 1
Not all zones are executing
Brian Brun
更新時間 2021-07-20 14:19:47 UTC
瀏覽: 4160   回覆: 1
BaiPhillips
更新時間 2021-07-20 20:42:15 UTC
瀏覽: 3866   回覆: 2
New lawn setting
更新時間 2021-07-21 01:54:26 UTC
瀏覽: 4058   回覆: 1
Netro Pixie with Google Home
fauxserious
更新時間 2021-07-21 19:50:41 UTC
What is the issue?
瀏覽: 4009   回覆: 1
Two electro valves activated at same time
Francesc Rodríguez
更新時間 2021-07-21 20:07:01 UTC
Why is not possible two valves operating at the same time if the pump can be operate correctly?
瀏覽: 4187   回覆: 1
Connect to a network
James Yates
更新時間 2021-07-22 21:08:14 UTC
瀏覽: 3485   回覆: 1
Keep Online
bechard
更新時間 2021-07-24 11:09:25 UTC
瀏覽: 3469   回覆: 0
Strange Whisperer Acrtivity
更新時間 2021-07-24 17:00:16 UTC
瀏覽: 4737   回覆: 5
Eric
更新時間 2021-07-25 05:56:52 UTC
瀏覽: 3527   回覆: 1
Installing New Netro-6
Debby Plenert
更新時間 2021-07-25 14:37:04 UTC
I removed an older controller and replicated the wiring when installing the new Netro.  Everything appears to be correct?  However, when watering is activated, the valves will fill up and vibrate or what not with water rushing internally.  But the sprinkler heads don’t pop up and no water comes out.  Any help here would be greatly appreciated.  Thanks!
瀏覽: 4371   回覆: 1
Rain sensor
更新時間 2021-07-26 12:13:34 UTC
瀏覽: 4129   回覆: 1
更新時間 2021-07-26 16:02:28 UTC
瀏覽: 4207   回覆: 2
David Farries
更新時間 2021-07-28 02:11:18 UTC
瀏覽: 4094   回覆: 1
