Move a Zone between Terminals
Gian Piero Pepino
Updated at 2022-06-03 12:13:40 UTC
Hello.
Is it possible to move a Zone, in my case: "Prato e back giardino" from Terminal 2 to Terminal 3 in a efficient way?
Let's say, for instance:  Copy Zone "Prato e back giardino" or Move "Prato e back giardino" from Terminal2 to Terminal 3, without being obliged to cancel the previous and reprogram all in a new Zone?
I've a problem with Terminal 2: the wire broke inside and I am not able to remove it ....
Thanx a lot
Gian Piero
View: 6812   Answer: 1
Sid Smith
Updated at 2022-06-02 22:21:42 UTC
View: 5232   Answer: 1
Reset rain delay to 0 (null)
Bruce Abbott
Updated at 2022-06-02 22:18:21 UTC
View: 5148   Answer: 1
PWS invalid
Giovanni Franceschini
Updated at 2022-06-01 19:16:43 UTC
Please enter a valid ID !
ISANREMO24
Thanks Giovanni
View: 5340   Answer: 1
Eric Berndt
Updated at 2022-06-01 19:03:43 UTC
View: 5001   Answer: 1
Eric Berndt
Updated at 2022-06-01 19:02:18 UTC
View: 4922   Answer: 0
Why is there no on/off
Eric Berndt
Updated at 2022-06-01 19:01:43 UTC
View: 5151   Answer: 2
Zone
Bertin Grégory
Updated at 2022-05-31 15:50:10 UTC
Bonjour
Serait-il possible d’activer 2 zones en même temps réfléchi
View: 7051   Answer: 2
Andy Ricco
Updated at 2022-05-31 06:12:27 UTC
View: 6225   Answer: 1
Setting up the schedule
Sasha Obradovic
Updated at 2022-05-30 22:11:58 UTC
I’m trying to setup schedule for watering for next five months, But watering schedule shows only for two next months. I check the settings and I do have a selected five next month. is there something I’m not doing right?
View: 6255   Answer: 2
Ron
Ron Ferrars
Updated at 2022-05-30 14:12:27 UTC
View: 8812   Comment: 1
Schedule screen
Dick Milde
Updated at 2022-05-30 14:02:03 UTC
View: 4161   Answer: 1
Schedule is empty?
Jacopo De Simoi
Updated at 2022-05-29 02:44:51 UTC
Best
 Jacopo
View: 4400   Answer: 1
Netro screwed up
Jack Davis
Updated at 2022-05-28 16:14:25 UTC
View: 4741   Answer: 1
Connection issues
Ant Va
Updated at 2022-05-27 09:57:09 UTC
View: 4917   Answer: 3
milanese
Updated at 2022-05-27 02:32:57 UTC
iPhone -
- Get app
- Crete account
- Go to connect timer
- Next
- Enter name and stuff, next
- Turn on unit, next
Please advise.
View: 5560   Answer: 1
Discover irrigation
Updated at 2022-05-25 06:52:34 UTC
View: 4586   Answer: 1
Pixie wifi connection
Luis Borrás
Updated at 2022-05-25 05:58:44 UTC
Luis
View: 4198   Answer: 1
Wayne Smith
Updated at 2022-05-24 20:51:31 UTC
View: 4307   Answer: 1
Bayoule Bayoule
Updated at 2022-05-24 18:50:51 UTC
JM
View: 5558   Answer: 2
