Night watering
John Kot
Updated at 2022-05-23 21:15:34 UTC
View: 5839   Answer: 1
Meteo app
Enrico Marion
Updated at 2022-05-23 17:03:37 UTC
View: 4321   Answer: 1
Updated at 2022-05-23 14:33:07 UTC
View: 8067   Answer: 1
MQTT port is blocked
Jose Juan Dios
Updated at 2022-05-22 11:51:44 UTC
Can you help me please?
Thankyou
View: 5733   Answer: 1
malfunction
Ramón Sellés
Updated at 2022-05-22 10:28:57 UTC
volume_up
content_copy
share
View: 4387   Answer: 1
Updated at 2022-05-21 17:31:03 UTC
View: 5047   Answer: 1
Battery in Pixie Reads 282%
David Halpern
Updated at 2022-05-21 13:50:23 UTC
View: 4944   Answer: 2
John Rowe
Updated at 2022-05-21 00:45:45 UTC
View: 5766   Answer: 4
Smart Zone Scheduling Problem
Jon Storch
Updated at 2022-05-20 22:11:43 UTC
Hello.  After turning on my sprinkler system back on for the summer this year the Netro has not worked correctly when in Smart Zone mode.
The scheduler will add a dozen of "mini" watering tasks where the next tasks starts immediately after the current one ends. (See picture)
I have tried resetting the system.  I currently need to have the Netro system disabled and run manual tasks to water my lawn.  What can I do to have my zones in Smart Zone mode and not have this problem?
View: 6092   Answer: 1
aspidiscelis
Updated at 2022-05-20 19:16:08 UTC
View: 5826   Answer: 2
Emilio
Updated at 2022-05-20 17:05:31 UTC
Buenas tardes,
Pronóstico o expectativas.
View: 4051   Answer: 1
Pixie automatic water
Shirley Johnson
Updated at 2022-05-18 18:20:36 UTC
My pixie won’t find my Wi-Fi. I’ve rebooted my router but didn’t help.
View: 5941   Answer: 1
Text in gray
Ignacio Sánchez
Updated at 2022-05-18 11:26:32 UTC
View: 4366   Answer: 1
Sleeping mode
Fabrice GOUFFRAN
Updated at 2022-05-18 10:11:40 UTC
View: 8812   Comment: 1
Home Tab
bdcfam
Updated at 2022-05-18 04:36:33 UTC
View: 4368   Answer: 1
Bruno
Updated at 2022-05-17 19:49:58 UTC
View: 4557   Answer: 1
Restrictions do not include minute limits
Cheryl Michael
Updated at 2022-05-17 03:03:27 UTC
I cannot find a way to reduce the minutes each station is watered. All stations on Eco boost. And some water almost an hour total (in 3 sessions) on allowed watering days. Our local So Cal restrictions are 10 minutes per station! How do I restrict  this?
View: 4063   Answer: 1
Fabrice GOUFFRAN
Updated at 2022-05-16 18:02:23 UTC
Good morning, Italy is my home, I recently started to use Netro replacing an old watering device I have used for several years, so far happy with my choice. I have one whisperer sensor device and I need 2 more but they are sold out on your online website, Amazon italy is also sold out with no forecast on new availability, where can I buy ?. Thank you.
View: 6297   Answer: 2
Weather .
Gianluca De Virgilio
Updated at 2022-05-15 17:39:09 UTC
Good afternoon. The Weather forecast avvailable are absolutelly not real. What can I do?
Could you help me to con figure weather underground?
View: 4434   Answer: 2
Sprinklers only turn for a few second
Gabriele Wiel
Updated at 2022-05-15 11:11:42 UTC
good morning
just installed his transformer burned out I had an electrician install a new transformer, now it works but the sprinklers only turn on for a few seconds, what can it be
This is a photo new transformer
View: 6013   Answer: 2
