Nero Sprite
Glenn Thurston
Updated at 2023-06-02 12:12:10 UTC
View: 5766   Answer: 1
Smart mode initial watering
Matt Ward
Updated at 2023-06-02 01:19:52 UTC
View: 6309   Answer: 1
kaitech
Updated at 2023-06-01 19:44:40 UTC
How can I troubleshoot it?
View: 5807   Answer: 1
Custom sprinkler flow rate
Jure
Updated at 2023-06-01 14:42:27 UTC
View: 6249   Answer: 1
Corinne Cleary
Updated at 2023-06-01 00:55:20 UTC
Please help.
View: 5875   Answer: 1
New grass from seed
D Berggren
Updated at 2023-05-31 01:11:58 UTC
View: 5861   Answer: 1
Arturo Camin
Updated at 2023-05-30 09:17:10 UTC
View: 6052   Answer: 1
Controller location
Francesco Zorzetto
Updated at 2023-05-29 13:55:31 UTC
Hi, during the installation phase of the controller, it was not possible to change the position regarding the geographical state of the machine, a US state remains by default and consequently, I can assume, the start times of the irrigation cycles are carried out with the time zone american time. How can I fix it?
View: 6529   Answer: 1
WU PWS request pixie-Z1
Richard B
Updated at 2023-05-29 01:04:07 UTC
View: 5851   Answer: 1
Rename device
3 Dorset Lake Avenue
Updated at 2023-05-28 09:51:48 UTC
View: 5814   Answer: 1
Gestione ritardi
Stebel
Updated at 2023-05-28 04:44:07 UTC
View: 5935   Answer: 1
Zone invert
Stebel
Updated at 2023-05-28 04:42:47 UTC
View: 5943   Answer: 2
Network Error with code: 3405
Stefan W.
Updated at 2023-05-27 20:05:45 UTC
Hi everyone. When I try to add another user in the app, I get the message „Network Error with code: 3405“
Any solution for this?
View: 6038   Answer: 1
One channel is always on
Stefan W.
Updated at 2023-05-27 19:58:05 UTC
Hi everyone,
I have a 6-channel Sprite with 6 hunter valves. 5 channels work perfectly, one seems to be always on. I tried a brand new valve, a reset of the Sprite, unplugged it from power, changed the wiring but nothing helped. Any ideas?
Cheers, Stefan
View: 6079   Answer: 3
Unable to delete 6-zone control unit from PC
Luciani Daniele
Updated at 2023-05-27 09:26:29 UTC
This morning I had to reset the 6 zone control unit. After the reset everything is fine from the Netro app. Instead, when I log in from a PC with my account, the old setting is detected and it won't let me delete it. The system returns error nvalid group ID 33131: invalid device status.
What to do?
View: 6292   Answer: 1
Can I back up my Netro?
Jacob Matheny
Updated at 2023-05-26 15:39:56 UTC
View: 6168   Answer: 1
Jacob Matheny
Updated at 2023-05-26 15:39:51 UTC
View: 6056   Answer: 0
Manuel Run delay
BOBBY BROWNE
Updated at 2023-05-26 00:37:50 UTC
Why is it when I hit manual run? There’s always a delay.
View: 5865   Answer: 1
Zones
Lea Schneider
Updated at 2023-05-25 23:29:01 UTC
My zones 5-12 won’t work but my zones 1-4 are working fine .    Any ideas what to do ?
View: 5946   Answer: 1
Rotor head
Sjors Janssen
Updated at 2023-05-25 19:15:07 UTC
I've just been using a Netro Spark to water my garden. I have set up 3 zones. Two of these zones have a rotor head sprinkler. However, they don't cover the same area. One of them rotates over 90 degrees. The other rotates 180 degrees. So I think the rotor head that covers the 180 degrees needs to run double the time of the 90 degree one. How can I set this? I've set the sqm for each head, but smart irrigation used the same times for both.
Kind regards,
Sjors
View: 5825   Answer: 1
