No light
Gabriele Gualtieri
Updated at 2023-05-10 17:13:50 UTC
View: 5933   Answer: 1
Whisperer GPS error
Guido Minciotti
Updated at 2023-05-10 15:11:55 UTC
View: 6129   Answer: 1
Alvaro Guardado
Updated at 2023-05-08 18:25:58 UTC
Dear support,
View: 5642   Answer: 1
Rain delay
David M.
Updated at 2023-05-07 04:30:25 UTC
I made a mistake on my netro spark and included a rain delay from the main screen.
How can I delete this delay?
View: 6124   Answer: 1
Francesco Zorzetto
Updated at 2023-05-05 23:09:14 UTC
View: 5835   Answer: 1
Looking for business partners in EU
Updated at 2023-05-04 02:54:48 UTC
Dear all,
We are looking for individuls in the EU (Spain or Italy preferred) who can work with us on shipping, inventory management and marketing. It is a paid, part-time and low-intensity work.
Please email to carolguo@netrohome.com if you are interested.
View: 7660   Comment: 3
Home assistant integration
Updated at 2023-05-03 16:22:33 UTC
I just developed a Netro Smart Garden integration for Home Assistant.
Take a look here if interested: https://github.com/kcofoni/ha-netro-watering.
View: 8373   Comment: 3
Michael Cayless
Updated at 2023-05-03 15:45:48 UTC
View: 5962   Answer: 1
Pixie Z1
Jason Willis
Updated at 2023-05-02 14:13:57 UTC
Jason Willis
Jason@wishsystems.biz
View: 6044   Answer: 1
Suggestion
Tom Carn
Updated at 2023-05-01 17:01:12 UTC
View: 5628   Answer: 1
Pixie connection
Sarroniz
Updated at 2023-05-01 06:20:22 UTC
I already have the Sprite 12 and want to add one or two Pixies.
Do I need the hub for the pixie or the sprite12 acts as hub?
Sergio
View: 6064   Answer: 1
Alexa
Federico Gietz
Updated at 2023-04-30 15:28:52 UTC
View: 5757   Answer: 1
Purchasing in the UK
Phil Middleton
Updated at 2023-04-27 21:05:51 UTC
I have purchased Netro Sprite from Amazon. I'm now trying to purchase a couple of Whisperer units. Is there anywhere in the UK as purchasing from the online shop the delivery charge is over $26.
Phil
View: 6372   Answer: 1
How to cancel schedule
Wayne Curdy
Updated at 2023-04-27 01:15:38 UTC
View: 5612   Answer: 1
0 Minute Zones?
Stephen Wyatt
Updated at 2023-04-26 12:59:02 UTC
View: 5558   Answer: 1
Katie Woggins
Updated at 2023-04-24 18:40:07 UTC
View: 5744   Answer: 1
Jim
Updated at 2023-04-24 17:38:25 UTC
View: 6065   Answer: 2
Updated at 2023-04-24 14:27:08 UTC
Sprite / app
Never before
Disconnection to wifi
Even when say : online
irrigation )
View: 6327   Answer: 1
Master error “open circuit”
Neil Lucey
Updated at 2023-04-24 14:09:12 UTC
Neil
View: 5831   Answer: 1
valves under relay
Alek
Updated at 2023-04-22 17:48:29 UTC
View: 8057   Answer: 1
