Whisperer stop working
Gianluca De Virgilio
更新時間 2021-05-11 15:34:15 UTC
Ideas?
瀏覽: 3999   回覆: 1
Smart water regulation
Albert Heinold
更新時間 2021-05-13 09:40:49 UTC
Thanks for any help.
瀏覽: 3676   回覆: 1
Whisper Pairing
Sang Peiris
更新時間 2021-05-13 12:11:59 UTC
Hello-  I have two new whisper devices. Both will not go into pairing mode.  Press power button six times and the light just blinks red on and quickly off. Press three times and same thing.
How do I get the whisper into pairing mode?
瀏覽: 4131   回覆: 1
Rainfall from weather station
更新時間 2021-05-14 16:50:13 UTC
瀏覽: 4049   回覆: 1
John Lillistone
更新時間 2021-05-15 09:23:08 UTC
Any ideas anyone?
瀏覽: 3841   回覆: 2
Watarering modes
更新時間 2021-05-16 07:44:57 UTC
Hi there
瀏覽: 4340   回覆: 2
Seed watering
Adrian Azzopardi
更新時間 2021-05-16 10:18:05 UTC
瀏覽: 3806   回覆: 1
Turning off wayer
更新時間 2021-05-16 21:29:12 UTC
瀏覽: 4148   回覆: 2
Programs Setup
fernando colon
更新時間 2021-05-18 04:44:56 UTC
I have 5 zones programmed daily in 15/20/35 mins intervals however when I goto the home screen I see them all in 15mins intervals... Seems as the home screen bypass' the current daily programmed schedule.  How do I have my programs run as intended 15/20/35 .ins intervals vs the 15mins it self imposed?
瀏覽: 4244   回覆: 1
Whisperer connexion
更新時間 2021-05-19 14:52:55 UTC
瀏覽: 4463   回覆: 2
amagalla
更新時間 2021-05-19 16:45:52 UTC
Edit:
The app on my tablet shows:
Server Status:    OK
Response time:  0.3 s
瀏覽: 4674   回覆: 2
bad wireless?
amagalla
更新時間 2021-05-19 16:50:44 UTC
Tony
瀏覽: 3934   回覆: 1
Netro Pixie Timer
claudinne
更新時間 2021-05-20 17:09:36 UTC
瀏覽: 3923   回覆: 1
Mitch Green
更新時間 2021-05-20 22:11:37 UTC
瀏覽: 4015   回覆: 1
Learning
John Conley
更新時間 2021-05-21 12:05:43 UTC
瀏覽: 3759   回覆: 1
Sensor usage
Ilya Lifshits
更新時間 2021-05-22 08:17:29 UTC
Hi ,
Ilya
瀏覽: 3830   回覆: 1
Brad Grizzly
更新時間 2021-05-23 03:42:20 UTC
瀏覽: 3695   回覆: 1
Connect one whisperer to two pixies
jmkluft
更新時間 2021-05-24 14:14:03 UTC
For the moment, I have one whisperer connected to one pixie, and everything is working fine.
I have a question though, if I would add another pixie to control another watering zone, can I connect the same whisperer to that second pixie?
In other words, can I connect one whisperer to two pixies?
Thx,
JM
瀏覽: 4025   回覆: 1
banaszar
更新時間 2021-05-25 17:23:58 UTC
瀏覽: 3713   回覆: 2
Douglas Peale
更新時間 2021-05-27 22:32:59 UTC
瀏覽: 3897   回覆: 1
