Fabio Pellizzoni
更新時間 2021-04-13 20:10:43 UTC
Do you have any idea why ?
瀏覽: 3841   回覆: 1
How to Set Schedule?
tonycurry
更新時間 2021-04-14 02:13:12 UTC
瀏覽: 3919   回覆: 1
Manual start on demand
Krzysztof Wiater
更新時間 2021-04-14 03:34:58 UTC
I just got unit garden hose pixie unit. I am looking for a manual watering on demand button. I want to be able to turn it on and off an needed. Right now i see I have to wait 1 hr or so to turn it on. Am I missing something here? Please help. Thanks in advance.
瀏覽: 3998   回覆: 1
Time zone not supported
Havre de Grace
更新時間 2021-04-15 08:11:30 UTC
I keep getting this error when I try to put my address in Jersey, Channel Islands.
瀏覽: 3624   回覆: 1
How to delete a device
Carles
更新時間 2021-04-16 12:33:31 UTC
瀏覽: 4051   回覆: 1
Multiple Pixies?
J Forrest
更新時間 2021-04-17 03:33:18 UTC
瀏覽: 3812   回覆: 1
Whisperer sensor soil type
Aki Lan
更新時間 2021-04-17 13:47:25 UTC
Is whisperer sensor able to know your soil type due to drain capacity?
瀏覽: 3845   回覆: 1
dougbrandes
更新時間 2021-04-19 10:06:30 UTC
瀏覽: 3793   回覆: 1
Email address
Troy pascoe st
更新時間 2021-04-19 11:01:30 UTC
瀏覽: 3798   回覆: 1
Michael Sheahan
更新時間 2021-04-19 21:19:54 UTC
瀏覽: 3853   回覆: 1
Mitch Green
更新時間 2021-04-20 00:44:59 UTC
瀏覽: 4347   回覆: 1
Jason
更新時間 2021-04-20 21:49:32 UTC
瀏覽: 3669   回覆: 1
Weather data
Vardhan Rajkumar
更新時間 2021-04-21 18:03:34 UTC
Vardhan
瀏覽: 4170   回覆: 1
Zones
dougbrandes
更新時間 2021-04-22 12:34:57 UTC
I only have 2 zones.  1st zone is programmed for only 2 days per week while the 2nd zone is programmed everyday and at a different time then the first zone.  However on the 2 days the first zone comes on, the second zone does not despite be programmed to.  As mentioned the on times are completely different.
瀏覽: 3677   回覆: 1
Trigger a single zone based on zwave switch
Moe E
更新時間 2021-04-22 14:54:46 UTC
My pools water fill line is connected as a zone on my sprinkler system. I would like to trigger turning on and off a zone based on a zwave switch status. Can this be done, or should I return my netro for a different system? It looks like netro does not have api access, and IFTTT is extremely limited. Thanks
瀏覽: 3874   回覆: 1
LAWN
更新時間 2021-04-23 23:08:09 UTC
Set up wifi
Neti URC - 87B (ok saved)
home netwok connected.
瀏覽: 3873   回覆: 1
Open tel zones atbthe same time
ivan hernandez
更新時間 2021-04-25 11:58:25 UTC
I have to activate two zones at the same time but i dont know how to do It.
瀏覽: 3761   回覆: 1
Can not connect to wifi
Andrei Stancovici
更新時間 2021-04-25 18:30:25 UTC
Hello. I have restarted my netro 16 after winter. First it connected ok and after a power lose i stopped connecting to wifi. I have tried everything. The light is solid as if is connected. Plese help. Thank you
瀏覽: 3622   回覆: 1
Netro app discover tab
Zee D
更新時間 2021-04-25 20:52:09 UTC
瀏覽: 3727   回覆: 1
Run Off Adjustment?
Carey Family
更新時間 2021-04-26 03:28:07 UTC
Hi Netro, I have fruit trees in clays soils and I have the whisper sensor helping me monitor the water. I have two issues right now. One is the sensor does not seem to detach much change in the moisture content in the soil, even immediately after an hour of watering. The other issue is I am getting run off during each watering cycle but I cant figure out how to spread out the watering or reduce them without going to a manual setting. Can you help me? Thank you!
瀏覽: 4034   回覆: 1
