Watering out of schedule time
Luca Cerini
Actualizado 2022-05-09 09:14:09 UTC
Luca
Ver: 2413   Respuesta: 1
No moisture reading
dsingelyn
Actualizado 2022-05-04 17:59:14 UTC
Suggestions?
Ver: 2823   Respuesta: 3
Rain stop
Javier Baruque
Actualizado 2022-05-03 14:52:20 UTC
Ver: 2451   Respuesta: 1
Whisper Sensor
Ian Moore
Actualizado 2022-04-26 02:55:10 UTC
Ver: 2707   Respuesta: 1
Actualizado 2022-04-24 01:45:07 UTC
Ver: 7020   Comentario: 1
doppia irrigazione
mauro croce
Actualizado 2022-04-22 10:52:27 UTC
Ver: 2713   Respuesta: 1
John Lillistone
Actualizado 2022-04-19 11:26:49 UTC
Ver: 2484   Respuesta: 1
Dsohunter
Actualizado 2022-04-13 14:39:27 UTC
Ver: 2681   Respuesta: 2
Parts for Pixie
Robert Squires
Actualizado 2022-04-11 14:11:50 UTC
Ver: 2587   Respuesta: 2
Flow rate
Sander Z
Actualizado 2022-03-14 12:34:05 UTC
Ver: 2642   Respuesta: 1
Netro is watering at 25F because it is misinterpreted weather
Ben Aggus
Actualizado 2022-01-11 12:15:06 UTC
I had to cancel watering because it’s 25F this morning. It’s because the weather is misinterpreted. The forecast today is 58/34, but that means it will be 34 for tonight’s low. Last night’s low was 25 and the Netro should look at that number for watering this morning.
Ver: 3016   Respuesta: 1
Weather not updating
Mick Faulks
Actualizado 2022-01-05 00:20:42 UTC
NetroWeather not updating, other weather apps only update if they are resubmitted every couple of days, is it possible to add other weather providers to the app?
Ver: 2982   Respuesta: 2
arubalsky
Actualizado 2021-12-01 13:44:22 UTC
Example:
Pixie 1 - Nov 24 - Good run
Pixie 2 - Nov 24 - Good run
Pixie 2 - Nov 26 - Good run
Pixie 1 - Nov 28 - Good run
Pixie 2 - Nov 28 - Good run
Pixie 2 - Nov 30 - Good run
Ver: 2862   Respuesta: 1
changelives
Actualizado 2021-11-13 23:40:38 UTC
Did I set it up incorrectly?
Ver: 2917   Respuesta: 1
Forecast not updating
Jacques
Actualizado 2021-11-07 10:29:17 UTC
Ver: 3058   Respuesta: 1
Actualizado 2021-10-05 10:53:54 UTC
Ver: 2985   Respuesta: 1
Issue with Smart Watering
Davide
Actualizado 2021-10-04 19:13:44 UTC
Hi Community!
Ver: 2719   Respuesta: 1
Lee Stocks
Actualizado 2021-09-25 01:02:17 UTC
Ver: 2712   Respuesta: 1
Juan Pascual
Actualizado 2021-09-22 17:57:24 UTC
Thank you very much.
Ver: 3100   Respuesta: 1
Lots of questions!
Thomas Ingleton
Actualizado 2021-09-22 13:39:22 UTC
Ver: 2802   Respuesta: 1
