overwatering
Actualizado 2025-05-20 12:55:43 UTC
- Sensor to report every hour
- skip watering if above 60%
- Sensor firmware 2.0.1
Ver: 101   Respuesta: 0
Smart Zones are random
Dave H
Actualizado 2025-05-19 15:27:46 UTC
Sprite-12
and/or
Ver: 107   Respuesta: 1
Panda88
Actualizado 2025-05-15 18:20:45 UTC
Ver: 162   Respuesta: 1
Whisperer 2
Stephen Brewer
Actualizado 2025-04-24 13:43:01 UTC
Steve
Ver: 299   Respuesta: 1
Matt
Actualizado 2025-04-08 16:25:11 UTC
Ver: 448   Respuesta: 1
Discount
darla
Actualizado 2025-01-30 20:05:17 UTC
Darla Carpenter
Ver: 1036   Respuesta: 1
Netro offline
Brett Gardner
Actualizado 2025-01-20 00:02:43 UTC
Suggestions?
Hard reset?
Brett
Ver: 1164   Respuesta: 1
Fat Cut
Actualizado 2024-12-29 07:11:04 UTC
Ver: 1333   Respuesta: 1
Zine will not run
TJ Woods
Actualizado 2024-10-27 14:40:45 UTC
Ver: 1674   Respuesta: 1
1 zone not watering
cowlo@xtra.co.nz
Actualizado 2024-10-01 01:41:13 UTC
Ver: 1762   Respuesta: 1
Pierluigi Cilli
Actualizado 2024-09-08 07:29:59 UTC
Ver: 1808   Respuesta: 1
Can't get desired watering time
Fabio Silvestri
Actualizado 2024-07-24 19:24:30 UTC
I'm struggling to setup watering time, even after third season im using this app.
As per my settings, EPA suggest to water every day, 30 minutes a day for each zone. The grass is getting sick as all past 2 years, cause the frequency is too high.
I would expect it to water for 1 hour, each 3-4 days. This is what i call "deep watering".
I tried following settings, the frequency decreases, but no way that i can increase the watering time which remains 30 minutes.
Help please
Ver: 2138   Respuesta: 1
Connection
jackielaith
Actualizado 2024-07-21 04:36:32 UTC
Can't connect to the internet with this app
Ver: 2036   Respuesta: 1
Bug in Smart watering Algorithm
texan4ever521
Actualizado 2024-07-16 18:53:40 UTC
I would like to know how to get a serious bug in the smart watering algorithm resolved.
I live in north Dallas.  All of our soil is clay.  Most yards (like mine) have Bermuda grass, which is extremely drought tolerant.  This grass grows roots several feet deep and can survive with zero watering for 3 weeks after a downpour that saturates the clay.  (I can show you green grass in a yard that is hard as a rock)  During mid July to mid September the average low is 80 and the high is over 100.  Bermuda grass will go dormant(not dead) if not watered during summer.  You can easily keep the yard looking decent with only 10 minutes of watering per week.
I bought my house in 2020 and it came with a Netro.  After a summer of use, my wife and I failed to look at the auto-pay CC card water bills.  We had accidently spent thousands of dollars on yard watering during the summer. (I can show the water bills)!  (FYI, I had each zone set to the max ECO level)  Instead of buying a new timer, I changed smart-zone to basic instead of advanced and setup very detailed schedules.
My timer got hit by lightning back in May.  I bought a new one and set it up.  I failed to notice that the default value for new zones is "smart zone enabled with advanced setting".  Even though I had set up manual programs the timer found 'loop holes'.  The advanced mode was watering some zones as much as 70 minutes in 1 WEEK!  (compared to previous 10 min a week).  My water bill went from $160 to $400 ( at least I caught it before it got to $800 again).
This bug has literally cost me thousands of dollars with a feature that is supposed to be saving me money.  I am not asking for compensation, it was my mistake that that I failed to look at the schedule and CC auto-pay.
But this bug is ridiculous.
How do we get the following implemented:
1) Global setting for water conservation (impacts all zones) that limits the max per week and max per month that a zone can be watered
2) Budgets inside manual programs that will set limits for max per week and max per month.
3) expand frequency for programs to be across 14 days instead of 7 days
4) notifications from app that informs owner of minutes watered per week and per month.
Ver: 2088   Respuesta: 0
2 zones must run the same amount of time
Actualizado 2024-07-06 15:35:53 UTC
Hi there
I have the garden zones like the diagram. And I want zone 4 a 3 run the same amount of time. Currently they use different whisperers and have different schedules what makes the grass to present in summer dry patches. I would like to force to run 3 and 4 the same amount of time.
Should I use only one whisperer attached to both zones (3 and 4)?
Ver: 2415   Respuesta: 3
Netro sprite-6 with power adapter 600 ma?
Nuno Fs
Actualizado 2024-06-28 12:33:25 UTC
Just bought a Netro sprite-6 and a power adapter 600 ma but the sprinklers go up but not down, why? Could it be the amperage?
I exchange the power adapter for a 800 mA and i still have the same problem.
If i do a manual irrigation and turn  it off in the middle it doesnt turn off,but if i tried once more to turn it on it turns it off....
Nuno
Ver: 2128   Respuesta: 1
programs overlaping (smart scheduler and watering adjustment)
Actualizado 2024-06-25 10:19:26 UTC
The smart schedule overlaps with the watering adjustment program that runs when the moisture goes below a %.
Yo can see here that zone 5 run 10 minutes the program and then 37 minutes the scheduler.  It has no sense and it is a waste of water.
  1. After the watering adjustment run, the smart scheduler should recalibrate the timing based on the humidity of the land.
  2. I have the whisperers, the whisperer should monitor the humidity and stop the smart watering once it reaches 99% of humidity but it seems the program runs all the way.
This could be improved in the application.
Thanks for your support and keep up the good job
Ver: 2220   Respuesta: 1
Need a notification, other than in calendar, when watering doesn't work.
Jake Tanner
Actualizado 2024-06-16 22:53:34 UTC
Apparently there are times when the wifi connection to one of our Pixie devices is not reliable.  Yes, I should work on that.  However, it has worked flawlessly in the past, and this is something new.  Nonetheless, when the water schedule fails because of no wifi signal, there should be some kind of notifcation OTHER than having to open the app, go to the calendar, and look for the tiny red icon.  The app is right there on the phone, and could generate a notification.  The app has the email address and could generate a notification.  The current method is borderline dysfunctional, and mostly useless.
The main screen can say "Watered 10 hours ago"  .. but the calendar OBVIOUSLY shows that that even did not happen.
Ver: 2143   Respuesta: 1
Rain skip only
Shawn C
Actualizado 2024-06-02 21:09:04 UTC
How do I setup the Netro to only check for rain and skip the rainy days ?  I don’t want it to enable smart watering and change my watering schedule but I would like it to detect and skip rainy days.  Thanks!
Ver: 2248   Respuesta: 1
SMART WATERING MODES
Javier NM
Actualizado 2024-05-12 06:32:07 UTC
Is there an article explaining the different watering modes of smart watering, more that the one line info on the menu? I am looking at information like levels of humidity pursued, depth of watering, or circumstances under which each mode is recommended.  Thank you
Ver: 2493   Respuesta: 1
