Wafering even when raining
Fabio Silvestri
Actualizado 2024-05-07 19:59:22 UTC
I don't understand the logic behind watering after training. Yesterday and today we had heavy Rain, but the Smart schedule plans to start in 9 hours. In the app I also set to stop watering the day before and after Rain, but that seems to have no effect. Temperatures are low as well, i wouldn't expect watering to start before at least 10 days.
Ver: 2486   Respuesta: 1
Whisperer 2 problems
Bruno
Actualizado 2024-04-17 20:54:19 UTC
As you can see the humidity sensor give some strange readings...
How can change those values in such way without touching the sensor or watering. I'm scared of the reliability of such things...
Ver: 2533   Respuesta: 1
Skip watering did not work
Actualizado 2024-04-17 12:50:29 UTC
I have the whisperer to avoid watering over 40% humidity, but the system did not skip it
Ver: 2439   Respuesta: 1
Water time
Wil
Actualizado 2024-04-17 04:36:26 UTC
How can I get this to water a certain time.  Like my gardens at 6am?
Ver: 2308   Respuesta: 0
Waters too much
Wil
Actualizado 2024-04-17 04:34:42 UTC
I inputted my own program. I want it to water the durations I entered.  It doesn't.  How can I turn the so called smart feature off?
Ver: 2501   Respuesta: 1
Zone 1 watering everyday
antonio.manso@gmail.com
Actualizado 2024-04-13 05:55:10 UTC
I have 9 zones configured, all the same. Zone 1 water everyday while the rest no. How can I fix it? It does not need water everyday
Ver: 2400   Respuesta: 1
pixie - water inside box and battery housing
veniamin
Actualizado 2024-03-02 09:46:44 UTC
Pixie stopped to connect. Removed battery and found water inside battery housing. All contacts except one of battery are very rusty.
Trying to clean. Water also inside battery / battery box
Is it safe to dry and charge?
How to prevent water from entering the box?
Ver: 2571   Respuesta: 1
Wifi icon
Carmelo Anaya
Actualizado 2024-02-27 10:19:11 UTC
What does this WiFi icon mean?
Ver: 2574   Respuesta: 1
Internet off - sprinklers on/off intermittently
Luke Johnson
Actualizado 2024-02-17 22:49:05 UTC
We have an internet outage - Netro knows the smart watering cycle and continues to turn on through the stations at the correct time, however runs intermittently. 5 seconds on, 1 min off. Is there anything I can do to help stay on?
Ver: 2581   Respuesta: 1
Stop manual mode
Martina Brasesco
Actualizado 2024-02-04 15:19:31 UTC
Buongiorno,
ho appena installato il mio nuovo NETRO, ma non riesco a stoppare l'irrigazione che è partita automaticamente non appena lo ho installato. Potreste aiutarmi?
Ver: 2456   Respuesta: 1
Moisture watering adjustment
Actualizado 2024-01-09 20:27:04 UTC
Hi there I have one of the whisperer that doesn't allow to adjust watering below 50%,
Sensor number 2 in my installation.
All the rest I can chose lower values
Ver: 2634   Respuesta: 1
Richard
Actualizado 2024-01-07 22:48:08 UTC
UPDATE 8/1/2024
UPDATE: 5/1/2024
UPDATE: 4/1/2024
ORIGINAL:
Ver: 3512   Comentario: 11
PM time
Cacho
Actualizado 2023-12-31 19:38:05 UTC
Hello, need help.
I cannot enter PM times on program.
Always return to AM. Not possible program at night.
Ver: 2412   Respuesta: 0
Whisperer maintenance
Fabrice GOUFFRAN
Actualizado 2023-10-11 02:34:36 UTC
Ver: 2519   Respuesta: 1
Yellow exclamation mark
MyGowdy
Actualizado 2023-10-07 23:05:24 UTC
Phil Middleton
Actualizado 2023-09-30 12:48:53 UTC
Kind regards
Phil
Ver: 2740   Respuesta: 1
kamiller42
Actualizado 2023-09-29 15:44:58 UTC
Ver: 2443   Respuesta: 1
David Solis
Actualizado 2023-09-14 21:05:39 UTC
Thank you in advance
David
Ver: 2791   Respuesta: 2
smart zone advanced range
Leandro
Actualizado 2023-09-12 17:37:36 UTC
Thanks for the reply
Leandro
Ver: 2452   Respuesta: 1
Soil moisture adjustment
Actualizado 2023-09-12 01:34:23 UTC
Ver: 2721   Respuesta: 1
