New seeding
Douglas Ely
Actualizado 2018-10-09 23:09:48 UTC
Here in ocean city NJ, when we seed for new grass we need the water to come on twice daily to start germination. When I set my Netro to “new plant” and the soil type to “sandy clay” which is the top layer, the controller had only been watering every 2.21 days. The soil is dust dry. I don’t want to have to make gross adjustments. That is why I bought Netro. What’s wrong?
Ver: 4819   Respuesta: 3
New grass seed
Dan R
Actualizado 2018-09-09 21:47:24 UTC
It would be great to have a feature that runs the sprinklers three times a day for 7 days when I put down new grass seed. I can build a program for this and it does not take very long. It would be a nice feature to have this built into the app.
Ver: 4125   Respuesta: 1
Program for new grass seed?
Brian Killian
Actualizado 2018-09-04 11:18:30 UTC
Does netro have a program for new grass seed?  I'm going to oversees later this month and was wondering how to set my sprinklers to get the seed to grow.
Ver: 4003   Respuesta: 1
How do you set weather cancelling programs
Richard Spooner
Actualizado 2018-08-24 01:08:49 UTC
Can’t figure out how to have the weather app stop the sprinklers
Ver: 4312   Respuesta: 1
California Native Plants
Anthony M
Actualizado 2018-08-08 22:15:43 UTC
It would be nice if more California native style plants (dry climate) were included in the database - or at least that sort of watering style (much less frequent/deep) be available as an option.  I find that when relying on the smart watering with generic salvia hybrid selected for plant type, the water usage is actually higher than the manual program i had set before, especially now in summer months I feel it might be overcompensating.  I'd like to be able to rely on the "smart" aspects, but not sure it makes sense given the higher water usage so for now will probably be forced to go back to manual programming instead.. If anyone has some experience/suggestions on matching these types of plants up with what is in the database I'm all ears as well.  Thanks!
Ver: 4493   Respuesta: 2
Rain vs moisture
Actualizado 2018-08-06 01:15:02 UTC
Wonder why the soil moisture doesn't change to 100% after a big rain in my area?  The soil moisture percentage is important since this might trigger the auto watering (water will kick in when the max moisture setting is greater than the actual moisture  percentage)
Ver: 4667   Respuesta: 1
Two zones on same spot
Actualizado 2018-07-31 22:06:08 UTC
I have 4 zones. Two of these cover the same piece of ground. One zone has pgm sprayers and the other zone has regular sprayers .But they cover exactly the same area. How do I tell the app this so that it knows that running the sprinklers for one zone waters the same trees and grass as the other zone?
To try and clarify the question - these zones cover the same physical piece of ground, (they overlap 100%) but netro doesn't know that, so it will water one zone and think the other zone is still in need of watering - and thus water the same grass twice. (each zone once so the same grass twice).  Netro's algorithm for determining soil moisture levels can't work if it doesn't realize these two zones are the same physical piece of grass.
Ver: 4816   Respuesta: 2
EPA Recommendations
bmcginni
Actualizado 2018-07-14 11:30:12 UTC
In the zone settings, the app offers different types of watering, for example, regular, deep watering, boost, etc. One is labeled EPA.
What are the differences between the settings and watering times/amounts for: regular, boost, and EPA?
Ver: 4626   Respuesta: 1
Same Zone Settings, Different Results
bmcginni
Actualizado 2018-07-14 11:23:00 UTC
Hello - I have a 9 zone system. I have set all of the zones with the exact same settings for type, grass, etc. I do not have any sensors.
However, the app shows the zones having different moisture levels, and waters certain zones differently than others, even though the settings and system location are the exact same.
Can you help me understand why the system would treat these identically programmed zones differently
Ver: 4637   Respuesta: 1
Smart zone watering some zones multiple times
Jason Warren
Actualizado 2018-07-10 11:29:26 UTC
I have eight zones with smart watering enabled for all zones. I noticed this morning when looking at scheduling that a few of the zones will water multiple times in the same morning. For example, Zone one will water for 4 minutes, Zone 2, Zone 3 excetera. Then it goes back to Zone 1 for 3 minutes, and maybe zone for for 7 minutes. Is this normal?
I have inserted a screen shot.Notice the zone, "house left."
Ver: 4600   Respuesta: 1
Two locations
Robert Garlick
Actualizado 2018-06-22 13:31:35 UTC
I have a system working in Florida and I just wanted to do the same thing in Kansas and I bought it and I have wired it but I haven't plugged it in because I don't know how I'm going to control each different location and I'm afraid something might go wrong and I won't be able to water in Florida.
So how do I control each separate location with the same phone?
Ver: 4713   Respuesta: 1
