Does Netro whisperer underestimate moisture?
Rick Agrawal
Actualizado 2020-07-16 19:12:17 UTC
I added a whisperer to one of our zones. Recently the moisture content was between 25-30%. We are having a hot summer with many days with 110 degrees. I believed it and watered for good 15-20 minutes. It turned out despite all those water the soil moisture went up to 45-50%. I went and checked again, the soil looks pretty good and appeared moist.
Just curious if the whisperer tends to underestimate moisture?
Ver: 3257   Respuesta: 1
Watering Frequency
Andrei Stancovici
Actualizado 2020-07-16 05:36:44 UTC
Hello.
I installed my netro yesterday and now after watering all zones it shows me that the next watering will be in 5 days. It seems to be to far away in the future since it's 35 degrees celsius and sunny all day
Ver: 3113   Respuesta: 1
Smart watering issue?
Ananth
Actualizado 2020-07-15 13:14:40 UTC
Ver: 3332   Respuesta: 1
user manual in spanish
Alejandro
Actualizado 2020-07-14 10:00:20 UTC
Ver: 3338   Respuesta: 1
Not enough watering time
Homestead One
Actualizado 2020-07-08 20:04:00 UTC
I have 4 zones activated.
Please help.
Ver: 3384   Respuesta: 1
Arthur
Actualizado 2020-07-08 16:08:19 UTC
Ver: 3100   Respuesta: 1
Hozelock
Alan George
Actualizado 2020-07-06 18:50:08 UTC
Ver: 3183   Respuesta: 1
sw238
Actualizado 2020-07-05 15:42:38 UTC
Ver: 3169   Respuesta: 1
Michael Fortwengler
Actualizado 2020-07-04 19:06:14 UTC
Ver: 3136   Respuesta: 1
Rob and Susan Tartre
Actualizado 2020-06-24 20:13:25 UTC
Thank you for any help!!
Ver: 3807   Respuesta: 3
Certificate Expired?
Robohead
Actualizado 2020-06-19 20:03:10 UTC
Ver: 3381   Respuesta: 2
Andy Black
Actualizado 2020-06-15 21:10:38 UTC
Andy
Ver: 3070   Respuesta: 1
Actualizado 2020-06-14 12:28:36 UTC
Ver: 3471   Respuesta: 1
Frequent mode
Actualizado 2020-06-12 20:20:04 UTC
Ver: 3403   Respuesta: 1
Maegan Nelson
Actualizado 2020-06-10 08:59:42 UTC
Ver: 3270   Respuesta: 1
JDWalburg
Actualizado 2020-06-08 15:26:52 UTC
Ver: 3077   Respuesta: 1
Thanks for IFTTT
Joe Ryan
Actualizado 2020-06-07 22:38:39 UTC
Ver: 3286   Respuesta: 1
A way to dial it down
esassone
Actualizado 2020-06-07 01:51:41 UTC
Ver: 3008   Respuesta: 1
Moisture to Skip Watering
Actualizado 2020-06-02 23:59:08 UTC
Ver: 3342   Respuesta: 1
Smart Watering Adjustment
Tarudro
Actualizado 2020-05-11 20:56:22 UTC
Hi Guys,
Kind regards & stay healthy,
Lukas
Ver: 3562   Respuesta: 2
