Rearranging zones?
Kurt H
Actualizado 2020-05-23 19:17:20 UTC
Ver: 4898   Respuesta: 1
Pressure compensated drip hose
Simon Clark
Actualizado 2020-05-24 17:22:21 UTC
I use Netafin pressure compensated drip hose on all my beds and there doesn’t seem To be an irrigation type for that. Is it OK using the drip setting which seems to be for micro drippers.
Ver: 4766   Respuesta: 0
Chris Graham
Actualizado 2020-05-24 20:37:39 UTC
Ver: 4897   Respuesta: 1
Is a full time wifi connection required for watering? Or any other unattended modes of failure?
Chris Graham
Actualizado 2020-05-24 20:43:23 UTC
If wifi is disrupted will the controller continue to water acording to the most recently programmed schedules?
More generally are there any modes of failure (other than loss of power to the house) where the controller can unexpectedly halt watering?  It would be unacceptable to have one's garden die from lack of water if the system fails when one is away from home for a number of days.
Ver: 4943   Respuesta: 1
Actualizado 2020-05-25 16:08:09 UTC
Ver: 4565   Respuesta: 1
Web interface
Emanuele Floridia
Actualizado 2020-05-27 16:58:10 UTC
Ver: 4646   Respuesta: 1
Delay between zones
Nicholas Lydakis
Actualizado 2020-05-28 15:39:00 UTC
Ver: 4399   Respuesta: 1
baijuviswam
Actualizado 2020-05-28 18:56:02 UTC
Ver: 4238   Respuesta: 1
Jesse For
Actualizado 2020-05-29 08:33:36 UTC
Ver: 4294   Respuesta: 1
Missing Whisperer
guags99
Actualizado 2020-05-29 18:11:36 UTC
This season when I put my whisperer back out to monitor my garden bed I looked on the app and no longer saw that device. So I went through the process to re-add it to my network and my Netro account and I get an error message stating that that serial number is already registered.  Anyone have any thoughts on how I can de-register and re-register this device?  Thanks
Ver: 4414   Respuesta: 1
Smart things?
S D
Actualizado 2020-06-01 23:14:05 UTC
Ver: 3976   Respuesta: 0
Moisture to Skip Watering
Actualizado 2020-06-02 23:59:08 UTC
Ver: 4504   Respuesta: 1
Netro Sprite non apre le valvole
Simone Nolletti
Actualizado 2020-06-03 09:40:36 UTC
valvole hunter 24vac, netro non apre le valvole.
i collegamenti sono stati eseguiti come da istruzioni.
Quale può essere il problema?
Alimentatore 24v 1000ma e’ corretto?
Ver: 4661   Respuesta: 1
Watering metrics question
Egan
Actualizado 2020-06-03 16:09:22 UTC
Todd in Texas
Ver: 4653   Respuesta: 2
Metrosideros (Myrtaceae)
Alessandro Raffi
Actualizado 2020-06-03 21:09:16 UTC
Thanks a lot,
Ale
Ver: 6628   Respuesta: 1
Notes section per zone
Simon Clark
Actualizado 2020-06-04 07:13:33 UTC
Ver: 4436   Respuesta: 1
Timer
Gary Niederpruem
Actualizado 2020-06-04 12:08:43 UTC
Ver: 4205   Respuesta: 1
Upgrading from 6 to 12 zones
Carlos Oliveira
Actualizado 2020-06-05 21:10:19 UTC
Ver: 4480   Respuesta: 1
OPCIONES
Ernesto
Actualizado 2020-06-06 16:01:17 UTC
Ver: 4173   Respuesta: 1
A way to dial it down
esassone
Actualizado 2020-06-07 01:51:41 UTC
Ver: 4105   Respuesta: 1
