Andrea Merito
Actualizado 2020-05-08 07:20:50 UTC
hello,
Andrea
Ver: 4371   Respuesta: 1
Suited for exterio?
Joan Peiro
Actualizado 2020-05-09 01:50:15 UTC
Ver: 4585   Respuesta: 2
2 different water sources
Carlos Oliveira
Actualizado 2020-05-09 14:51:27 UTC
I have the netro connected to one water source.
Now I am going to install a vertical garden with very low flow and I want the source of water to be a different one from the main source for the garden.
Is there a way I can connect it as an independent solenoide valve that doesn't need to have the master turned on ?
Carlos
Ver: 4671   Respuesta: 1
Pixie Pending
Rich Keith
Actualizado 2020-05-09 19:07:11 UTC
Ver: 4307   Respuesta: 2
Chen Li
Actualizado 2020-05-10 05:45:08 UTC
Ver: 4243   Respuesta: 1
Unit system
Andrea DiPi
Actualizado 2020-05-10 08:11:33 UTC
Gooooddddmoooooorning!
Here where we are!!! Torino - Cincinnati - Alice Sping - Skagen - Macao - ......
Is it possible set the app whit a unit as metric or imperial or...Mars?!? It is very boring that some parameters are in metric an other in sqft x ex.
Ver: 4800   Respuesta: 1
Smart Watering Adjustment
Tarudro
Actualizado 2020-05-11 20:56:22 UTC
Hi Guys,
Kind regards & stay healthy,
Lukas
Ver: 4708   Respuesta: 2
where is the rst button
Jennml
Actualizado 2020-05-12 18:00:51 UTC
Ver: 4325   Respuesta: 1
Default rain settings
jbart65
Actualizado 2020-05-12 21:31:24 UTC
Ver: 4602   Respuesta: 1
hedges
Andrea Colombelli
Actualizado 2020-05-14 19:45:52 UTC
Ver: 4413   Respuesta: 1
No 2.4GHz wifi
Carlos Oliveira
Actualizado 2020-05-16 11:29:24 UTC
My netro has been working fine for the past many months.
Suddenly it stopped working and light blinks.
I try to configure the Wifi again and it states
I am sure my 2.4 GHz network is available there as I have 2 other devices 10 Cm away from the netro and are working fine at 2.4GHz
I can confirm that in my Orbi Router.
Any ideas ?
Carlos
Ver: 4750   Respuesta: 1
Link to smart light
Noam Leshem
Actualizado 2020-05-16 17:53:06 UTC
Ver: 4601   Respuesta: 1
EASTBOBDAM D
Actualizado 2020-05-17 13:18:19 UTC
Thanks in advance
Ver: 4366   Respuesta: 1
Yves Desrosiers
Actualizado 2020-05-17 18:31:27 UTC
Thanks for your help :)
Ver: 4556   Respuesta: 1
Watering program
Maciej Karpinski
Actualizado 2020-05-18 01:01:57 UTC
Ver: 4599   Respuesta: 1
Pixie sync Sprite
Sebastian Diaz
Actualizado 2020-05-19 02:50:59 UTC
Thanks you Sebastian
Ver: 4968   Respuesta: 1
Kobus Marneweck
Actualizado 2020-05-19 03:33:33 UTC
Ver: 4638   Respuesta: 1
Best settings for garden
Alexandre Morin
Actualizado 2020-05-20 11:01:20 UTC
thanks
Ver: 5156   Respuesta: 2
Roman Prochazka
Actualizado 2020-05-22 07:55:46 UTC
Many thanks for early answer
Best Regards
Roman
Ver: 4860   Respuesta: 2
Wayne Richards
Actualizado 2020-05-23 16:07:26 UTC
Ver: 4582   Respuesta: 1
