Conrtoler
John Zuzula
Actualizado 2024-10-19 23:45:24 UTC
Ver: 2706   Respuesta: 1
Tie the irrigation of two lines on the same garden
Francesco
Actualizado 2024-09-04 07:59:17 UTC
I have two irrigation lines on the same garden, is there any setting that would allow these two areas to be “tied together” such that they irrigate on the same day (session)? (Obviously first one line and then the other).
Ver: 3339   Respuesta: 1
Discrepancia APP y WEB
JM del Amo
Actualizado 2024-09-07 13:06:53 UTC
Ver: 3046   Respuesta: 1
Pierluigi Cilli
Actualizado 2024-09-08 07:29:59 UTC
Ver: 3103   Respuesta: 1
Broken whisperer sensor
Jesús López
Actualizado 2024-09-09 16:19:33 UTC
Hi everyone!
Ver: 3228   Respuesta: 2
Smart watering not working
Actualizado 2024-09-10 16:17:51 UTC
Ver: 3041   Respuesta: 1
Sensor
Kathleen Hamilton
Actualizado 2024-09-11 19:43:50 UTC
Ver: 3099   Respuesta: 1
Thomas Murphy
Actualizado 2024-09-18 12:39:46 UTC
Hello there!
Thank you so much!
Ver: 2979   Respuesta: 1
Zone 1 not watering
11807GFT
Actualizado 2024-09-24 23:25:59 UTC
Ver: 2982   Respuesta: 1
Schedules
jonathansalina
Actualizado 2024-09-28 11:11:52 UTC
Ver: 2901   Respuesta: 1
How do I?
Rockhead413
Actualizado 2024-10-01 00:08:51 UTC
Vincent Devlahovich
805-813-1216
Loyal customer
Ver: 2806   Respuesta: 1
1 zone not watering
cowlo@xtra.co.nz
Actualizado 2024-10-01 01:41:13 UTC
Ver: 3065   Respuesta: 1
Manual mode without delay
Phil Houghton
Actualizado 2024-10-04 23:27:59 UTC
Ver: 2727   Respuesta: 1
cjulian
Actualizado 2024-10-05 18:05:09 UTC
Ver: 2877   Respuesta: 1
Set up weather underground
Giovannini Alex
Actualizado 2024-10-05 18:35:32 UTC
Alex
Ver: 2970   Respuesta: 1
Water restriction schedule problem
Carolyn Simmons
Actualizado 2024-10-08 00:12:28 UTC
I cannot get the system to set up our county water restriction schedule. It is Wed and Saturday up to 10am in morning and after 6 pm at night. I would really like to run each zone once in the morning and once at night!  Any suggestions before I get fined $200.00?
Ver: 3064   Respuesta: 1
12330barryknoll
Actualizado 2024-10-10 01:51:03 UTC
Ver: 2860   Respuesta: 1
BrettEnyart
Actualizado 2024-10-13 18:02:06 UTC
Ver: 2855   Respuesta: 1
Sprite went offline
dkoford@gmail.com
Actualizado 2024-12-18 02:30:29 UTC
Ver: 2645   Respuesta: 1
Random Start
Mario Hardy
Actualizado 2024-12-23 12:56:07 UTC
Ver: 2447   Respuesta: 1
