更新时间 2019-05-14 07:01:36 UTC
浏览: 10624   回复: 2
Manual mode fail to shut off
更新时间 2019-05-16 02:05:13 UTC
浏览: 10163   回复: 1
Whisperer stopped working
Pelle Fisk
更新时间 2019-05-17 13:30:13 UTC
浏览: 10851   回复: 2
Hot weather algorithm
Joshua Berk
更新时间 2019-05-17 16:15:51 UTC
浏览: 10462   回复: 2
Steven V
更新时间 2019-05-18 13:08:55 UTC
浏览: 9279   回复: 1
David Claridge
更新时间 2019-05-18 13:21:53 UTC
浏览: 9245   回复: 1
Dennis N
更新时间 2019-05-18 17:52:30 UTC
浏览: 9231   回复: 1
Roianne Cox
更新时间 2019-05-19 13:52:50 UTC
浏览: 9164   回复: 1
jpmeyer81
更新时间 2019-05-19 15:04:11 UTC
浏览: 9785   回复: 1
Manually skip next watering
Randy Ziffer
更新时间 2019-05-19 16:47:13 UTC
浏览: 9608   回复: 2
Remote Access?
Oliver Pettit
更新时间 2019-05-22 01:53:35 UTC
Oliver
浏览: 9979   回复: 1
Can't see answers to questions
Stan Bumgarner
更新时间 2019-05-23 00:30:01 UTC
I can see the question and can see that someone has answered it. How do I see the answer?
Stan
浏览: 9397   回复: 1
Joshua Berk
更新时间 2019-05-23 18:39:21 UTC
浏览: 10038   回复: 1
Netro off line
更新时间 2019-05-25 02:59:21 UTC
浏览: 10212   回复: 1
Don’t Stop !!
Eduardo Ariste
更新时间 2019-05-26 11:27:42 UTC
浏览: 9364   回复: 1
Jon Storch
更新时间 2019-05-27 19:41:14 UTC
Why did it run this morning?
Jon Storch
浏览: 10094   回复: 1
Subsoil moisture level
Swaroop Jay
更新时间 2019-05-28 17:13:12 UTC
浏览: 8703   回复: 2
Zones
José Miguel Salcedo
更新时间 2019-05-28 20:03:07 UTC
Why  can't I water two zones at the same time
浏览: 9778   回复: 1
Netro offline and not watering
Mark
更新时间 2019-05-28 22:23:43 UTC
netro shows offline.  The app says zones are watering but no watering is occurring.   Plants are dying.
Retro device has a white light.
How do I fix this?
浏览: 9184   回复: 0
Using as a on/off switch
pgvolk
更新时间 2019-05-29 14:59:55 UTC
浏览: 8570   回复: 1
