Joshua Berk
更新时间 2018-10-10 06:22:09 UTC
浏览: 10491   回复: 3
Controller
Phil Samson
更新时间 2018-10-12 18:41:33 UTC
My controller shows that it’s online but the app is saying I’m offline. How do I correct this?
浏览: 9564   回复: 0
connecting to wifi..
Phani Gade
更新时间 2018-10-15 17:20:42 UTC
浏览: 9432   回复: 0
Moberley
moberleyj@verizon.net
更新时间 2018-10-17 16:59:29 UTC
浏览: 10296   回复: 1
George Zraick
更新时间 2018-10-27 20:05:15 UTC
浏览: 9829   回复: 1
Service
Matt Lasser
更新时间 2018-10-31 16:01:30 UTC
浏览: 10094   回复: 1
Skipping skipped?
livingwater71
更新时间 2018-10-31 16:11:03 UTC
浏览: 9430   回复: 1
EPA rebate status?
Joshua Berk
更新时间 2018-11-04 07:39:58 UTC
Hi I was wondering if we could get an update on where Netro is with an EPA rebate? We're aware Netro has applied, but any word or ETA on getting certification for rebates?  Thank you
浏览: 10756   回复: 3
Water pump shutting off
Ryan Cochran
更新时间 2018-11-26 02:32:24 UTC
浏览: 10037   回复: 1
Rebekah H
更新时间 2018-11-28 04:23:43 UTC
浏览: 9972   回复: 1
Sangjin Lee
更新时间 2018-12-15 18:56:48 UTC
Thanks in advance!
浏览: 15991   回复: 1
Leak detection
Joshua Berk
更新时间 2019-01-03 15:27:07 UTC
Rachio has a new leak detection device you can install on the pipe that talks to the controller letting it know if there's water flow that shouldn't be happening. Do you guys have plans to do anything like this? Would absolutely be interested in it!
浏览: 9887   回复: 0
St. Augustine
Spencer Vaughn
更新时间 2019-01-10 03:15:53 UTC
浏览: 13114   回复: 2
Tim Cox
更新时间 2019-02-02 01:35:59 UTC
浏览: 9992   回复: 3
Nathan Anderson
更新时间 2019-02-13 03:53:31 UTC
浏览: 10092   回复: 1
Scot and Michelle Cowan
更新时间 2019-03-03 17:04:51 UTC
浏览: 10885   回复: 1
Instructions about Replacing Toro System
更新时间 2019-03-20 08:07:29 UTC
Replacing Toro system
This page lists some instructions about replacing the common types of Toro system with Netro smart watering controller.
Example 1:
Toro model gk212-04
1. Connect the 2 white wires to the C slots, one on the left and the other on the right which is now occupied by a red one.
2. Move the red wire(currently on C slot) to M slot because it is for your master valve.
3. The last step is to connect the power then you should be good to go.
Example 2:
Toro IC 8.
The first slot of your current controller is master valve which should be connected  to "M" slot of Netro. The two wires in the second slot are common wires should be connected to the 'C' slot of Netro. The last step is to connect the power then you should be good to go.
Example 3:
Toro Model 53765 6 zones
The red and white wires are the commons wires and should go to the two "C" slots in Netro Sprite controller. You do not need to connect the gray and black wires as they are the power wires for the old controller.
浏览: 12283   回复: 0
更新时间 2019-03-20 08:03:05 UTC
Replacing old system
Example 1:
I check the pictures.
OLD                 Sprite
COM                any C slot
1                     1
2                     2
3                     3
4                     4
Example 2:
Example 3:
Example 4:
Other wires are not needed.
Example 5:
浏览: 10750   回复: 0
Overriding smart waterinh
mvernia
更新时间 2019-03-17 20:46:27 UTC
浏览: 9535   回复: 1
charu
更新时间 2019-03-21 16:27:21 UTC
浏览: 9317   回复: 1
