Products
  • Photo of Netro STREAM 1
  • Photo of Netro STREAM 2
  • Photo of Netro STREAM 3
Stream Eco, Smart Indoor Watering System
Price: $79.99
Model:
Power Adapter:
In Stock
Shipping Policy
Quantity
Netro Stream Eco
An automated drip irrigation system designed for the lushness of your potted plants.
Easy Scheduling
You can create any number of time-based or volume-based watering programs from the Netro mobile app. All settings and watering schedules are stored in the Netro cloud server for easy access.
Remote Control
Stream Eco connects to the Netro cloud service through the Wi-Fi network. You can turn on or off the water instantly from the Netro mobile app, regardless of whether you are home or traveling.
Rock-Solid Performance
Stream Eco stays plugged in, always online, and always stable — giving you reliable, real-time control.
Quick Installation
No special tool is needed to setup the system. The package comes with everything you need (including drip emitters and tubing) to build this advanced watering system in 5 minutes.
Model No.: STREAM ECO Box Contains: – Irrigation pump, holder, power adapter and cable, tubing, connectors, drip emitters, filter, plastic plugs Technical Specifications – Dimensions: 4.1 X 4.1 X 2.2 inches – Weight: 7.1 oz / 202 g – Tubing size: 4 mm (Inner diameter) – Operating temperature: 32 to 122℉ / 0 to 50℃ – USB charging current: 600mA – WiFi: 802.11 N, 2.4Ghz Warranty – 2-year limited hardware warranty
user_manual_stream_eco.pdf
